Shock rebuild kit : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 12-07-2012, 08:39 PM   #1
Kekoa
Kekoa's Avatar
Motorcycle: '05 600
Shock rebuild kit
Are there any shock rebuild kits i.e. seal kits? I couldn't find any on my own and only one of the shops I visited had a kit they could order. But it came with a replacement cartrige and wasn't just the seals, which is all I want. Everyone I talked to said that stock shocks are almost never rebuilt so I might be chasing shadows. I want a refresher, not an upgrade, so after market items don't fit in my budget.
Kekoa is offline   Reply With Quote
Old 12-07-2012, 09:56 PM   #2
Nafterclifen
Motorcycle: 04 GSX-R 600
Re: Shock rebuild kit
The OEM parts diagram does not show any replaceable parts (i.e. seals) on the shock. I'm assuming that yours is leaking and you want to fix it without upgrading? I would suggest looking for a used one on eBay.
Nafterclifen is offline   Reply With Quote
Old 12-07-2012, 10:14 PM   #3
fastboatster
Motorcycle: 2004 GSX-R 600(sold), 2003 GSXR600 beater bike
you can call racetech, i think. also, many dirtbike shops have shock rebuild parts (or at least, i 've seen a few online locations which sell rebuild parts for showa shocks), so you just need to measure the old seals.
fastboatster is offline   Reply With Quote
Old 12-07-2012, 11:10 PM   #4
fastboatster
http://www.moto-pro.com/ProductPage....PSID=MPSSH4616
how about this? that should probably work - i.e., your shock is 46mm with 16mm shaft (have one apart, so I also measured it). you can give them a call and ask if that's gonna work. and I think they have the seals separately.
http://www.moto-pro.com/ProductPage.asp?strMPSID=16SDS - that actually looks exactly the same as on my shock
http://www.moto-pro.com/ProductPage.asp?strMPSID=16SOS
or this:
http://www.moto-pro.com/ProductPage....ID=RKITSHOWA16
but imo, new seal head with all the parts should be a better bargain
Old 12-07-2012, 11:49 PM   #5
Kekoa
Kekoa's Avatar
Motorcycle: '05 600
Not leaking, high milage so it's over-due for an over haul. I appreciate the research fastboatster, but I'm not too keen on the "home make" seal kit. Not saying it wouldn't work, but there's no guarntee either. In other words; the the more affordable cost of the seals to rebuild the stock shock is close to the cost of a used shock on ebay. But the more expensive cartrige/seal kit is provided by a second party and backed by the shops work warrenty.
In short, I'll stick with what I have now.
Old 12-08-2012, 09:52 AM   #6
TheGeek
Stupid. Who's with me?
TheGeek's Avatar
Motorcycle: Anniversary Edition 600
Ship them to Traxxion Dynamics.I think it's about $300 for a full fork job. That includes their upgrades and all new consumables.
TheGeek is offline   Reply With Quote
Old 12-09-2012, 04:15 PM   #7
Kekoa
Kekoa's Avatar
Motorcycle: '05 600
$300 is way out of my budget, I could get a Ohlin shock from a shop down the street. But I found some usful information in the service manual while putting everything back together:
Old 12-09-2012, 05:15 PM   #8
TheGeek
TheGeek's Avatar
By the typical home mechanic. Suspension pros can do miracles.
Old 12-09-2012, 05:20 PM   #9
If you want to rebuild it yourself, you can find the seals and parts from Racetech. You could revalve it with one of their Gold Valves too while you have it apart if you wish.
Shock stuff is at the bottom
http://racetech.com/ProductSearch/2/...X-R600/2004-05
Although at the end of the day, you'd be better off just sourcing a used Penske or Ohlins off ebay or WERA or something. Even after you rebuild it, it's still the same lower quality stock hardware.
SPL170db is offline   Reply With Quote
Old 12-09-2012, 11:53 PM   #10
fastboatster
well, if the shock doesn't leak and seals look ok then why not just change the oil and be done with it?
Old 12-10-2012, 10:14 AM   #11
Kekoa
Kekoa's Avatar
Motorcycle: '05 600
That's why I can't justify a pricey rebuild, and aftermarket isn't cheap either.
What do you know about doing just an oil change? Doesn't part of it had nitrogen though? I don't have the space or tools to do it on my own. All the reputable shops I know don't have the tools to do a rebuild, and all the ones that do are stealerships.
Old 12-10-2012, 10:40 AM   #12
600k2
It's a Jersey thing
600k2's Avatar
Motorcycle: 600k2
I rebuilt the shock on my bike with Race Tech parts. Check for my shock thread.
600k2 is online now   Reply With Quote
