2 issues: starting and coolant pump : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-06-2012, 05:47 PM   #1
cirsory
cirsory's Avatar
Motorcycle: 06 600 track
1st. I don't think the coolant pump is working. I filled the radiator once and try to burp the system but the level wont go down unless its boiling over(leaving the cap off). I squeeze the tubes(any of the lower ones) and the water level rises. Is there a sure way to check if its working or not or does it only kick on at a certain temp? Or maybe I didn't have to burp it somehow?
2nd and this one has me completely stumped with no clue what to do. It will not start unless i put starting fluid into it. Just a quick shot into the intakes and it'll fire right up. The confusing part is that it is getting fuel and spark and will continue running for as long as I let it. I've had it running 5+ minutes revving the engine and it wont die, but if I shut it off and try to start again it won't go until it has more starting fluid
Currently rebuilding a wrecked salvage 06 GSXR-600 for track duty. FINISHED
cirsory is offline   Reply With Quote
Old 12-06-2012, 06:50 PM   #2
2movethesoul
2movethesoul's Avatar
Re: 2 issues: starting and coolant pump
I had a hell of a time burping my coolant when I drained it to powdercoat the water pump cover.
Remove the water pump cover and get all the coolant out of the system.
Top it up and run the bike for a minute or so while blipping the throttle.
Top it up and it's a wrap!
2movethesoul is offline   Reply With Quote
Old 12-06-2012, 07:47 PM   #3
Chugs
Let's ride!
Chugs's Avatar
1. There is also a bleeder screw for coolant burping.
2. Maybe your idle speed is too low??
Chugs is offline   Reply With Quote
Old 12-06-2012, 08:17 PM   #4
cirsory
cirsory's Avatar
talking it over with a buddy, he suggested swapping the fuel relay. His tought was that if that has weak voltage passing then it could keep it from pushing enough fuel to the injectors. I did this and it fired up without hesitation. I'll keep trying just in case its a fluke some how or if it fired because the engine is warm now at 100F.
Old 12-06-2012, 09:26 PM   #5
MacBayne
anyone else smell poop?
MacBayne's Avatar
Motorcycle: K6-600 track, K9-750 white/silver street.
for bleeding, look at page 7-11 in the manual. another thing you can do if you have frame sliders is lean the bike fully on the left side with the rad cap off for a minute, run the bike for a minute, repeat. i do it every time i change water.
MacBayne is offline   Reply With Quote
Old 12-06-2012, 10:15 PM   #6
cirsory
cirsory's Avatar
Yeah I did look at the manual to verify. I know how to do it but it doesn't seem to be cycling through if that makes sense?
Old 12-06-2012, 10:44 PM   #7
MacBayne
MacBayne's Avatar
are you warming it to temp too? maybe you are just good at pouring coolant, and there are no bubbles.
Old 12-06-2012, 11:37 PM   #8
Goobersbro
Goobersbro's Avatar
Motorcycle: 07 GSX-R 600
Yea sometimes when I fill mine it doesn't need burped other times it does. You will know though. Just start the bike and let it warm up. It should warm up nice and slow, but if it gets to hot shut it off.
If you want to test if its working crack the bleeder bolt on the water pump cover. Mine will shoot out if removed
Goobersbro is offline   Reply With Quote
Old 12-06-2012, 11:46 PM   #9
cirsory
cirsory's Avatar
deleted
Old 12-06-2012, 11:48 PM   #10
cirsory
cirsory's Avatar
it went up to 180 in a few minutes before i turned it off, probably about 3-5 minutes it took. Take off the bleeder bolt with it off or running?
Old 12-06-2012, 11:55 PM   #11
xaznperswaesonx
xaznperswaesonx's Avatar
Motorcycle: K7 GSXR-600
Running.
Bike running , water pump should too. With bleeder open, bike running, at warmed temp assuming no air in the system :
- coolant squirts out at bleeder = water pump is operational
- coolant doesn't squirt out = water pump the brokeh!
Sent from my Galaxy Nexus using Motorcycle.com Free App
xaznperswaesonx is offline   Reply With Quote
