I need help popping and rich smells : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-06-2012, 01:38 PM   #1
RACER4R
I HAVE A 2000 CARB GSXR 600 I GOT IT FROM A KID AND IT WAS RUNNING GOOD IT JUST KEPT VAPOR LOCKING SO I REBUILT THE CARBS AND BOUGHT NEW COILS IT QUIT VAPOR LOCKING BUT NOT IT WONT REV UP PAST 8500 AND IT SMELLS RICH LIKE BEFOR I NEED HELLLLLPPPPP
RACER4R is offline   Reply With Quote
Old 12-06-2012, 02:13 PM   #2
ccmhunt
Carb Ninja
ccmhunt's Avatar
Motorcycle: 96 GSXR750, 07 CBR1000RR
Re: I need help popping and rich smells
First, get out of CAPS.
Second, if it will not rev past 8500,did you connect the float bowl vents T to the front of the airbox? Does it rev freely in neutral but not under load?
ccmhunt is online now   Reply With Quote
Old 12-06-2012, 03:08 PM   #3
Armi
Superbike Champ
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
Connect the float bowl vents to the front of the airbox, like what ccmhunt said!!!
sTRANGE i HAD THE ABOVE IN CAPS LOCK
Armi is online now   Reply With Quote
Old 12-06-2012, 05:00 PM   #4
RACER4R
iam pretty shure i hooked it up when i put it all back togeather and it does the popping while in nutural sorry about the caps i was on the work comp lol
Old 12-06-2012, 05:12 PM   #5
ccmhunt
Carb Ninja
ccmhunt's Avatar
I am not asking about the popping, you said it wont rev past 8500: if it wont rev past thatwhile under load, but will in neutral, thats a sign you forgot to hook it up, of its blocked. Not referring to popping here. Popping can be either extremely lean or rich.
Old 12-06-2012, 08:33 PM   #6
nemesis119
nemesis119's Avatar
Motorcycle: 2000 gsxr 600
...deja vu?..i swear ive seen this line a few times....or hundred..
And seems to follow the same question too..
Coincidence? : :
nemesis119 is offline   Reply With Quote
Old 12-06-2012, 10:00 PM   #7
ccmhunt
Carb Ninja
ccmhunt's Avatar
Coincidence? : :
So I shouldn't give the logical response simply because its reoccurring?
Sent from my DROID3 using Motorcycle.com App
Old 12-06-2012, 10:29 PM   #8
TwistedMister
TwistedMister's Avatar
prune juice...
TwistedMister is offline   Reply With Quote
Old 12-07-2012, 02:46 AM   #9
Armi
Superbike Champ
Armi's Avatar
I enjoy answering that one, cos' it looks like I know what I'm talking about
Old 12-07-2012, 09:42 PM   #10
RACER4R
well guys i might sound dum cuz iam a green horn to this stuff but you guys are talking about the vacume lines that hook up to the 2 little solonids right or is it the other hose at the front of the carb the one on the solonids was unhooked so iam hopeing it was it and my fuel filter had a little crack in it
Old 12-07-2012, 10:02 PM   #11
nemesis119
nemesis119's Avatar
No..i was getting at having the op do a search is all..
Old 12-08-2012, 12:35 AM   #12
ccmhunt
Carb Ninja
ccmhunt's Avatar
No..... That's not what we were referring to at all. How could you tell us in post #4 that you were pretty sure you hooked it up, when it is now apparent that you don't know your float bowl vent tube to airbox connection, as you are now referencing solenoids which are a separate system and supply additional air to the main air jet/emulsion tube at midrange to lean it out and aid in emulsion, having nothing to do with pressurizing float bowls above atmospheric pressure?
Old 12-08-2012, 08:02 AM   #13
RACER4R
like i said iam new to this stuff the one at the front of the carbs was hooked up witch i fugured was the vent hose thats why i said the i was pretty sure it was hooked up and does anyone have a diagram or a picture of how the vaccume hoses on the soloniods are supposed to be hooked up and the help is greatly appricated
Old 12-08-2012, 08:11 AM   #14
TT750
Motorcycle: 99 750
FYI all caps is equivant to yelling in a forum
Old 12-08-2012, 08:19 AM   #15
ccmhunt
Carb Ninja
ccmhunt's Avatar
sure I have lots of pictures but I'm at work right now
Old 12-08-2012, 08:57 AM   #16
RACER4R
cool thanks for the help
Old 12-08-2012, 10:25 AM   #17
TT750
Motorcycle: 99 750
maybe edit your first post
Old 12-08-2012, 10:48 AM   #18
dj_smurph
Motorcycle: 98 600 srad,97 aprilia chesterfield rs125
Look at the airbox closest to handle bars there should be a tube going to the carbs from there.
dj_smurph is offline   Reply With Quote
Old 12-08-2012, 04:30 PM   #19
Armi
Superbike Champ
Armi's Avatar
Does this help
The y piece hose we're on about is at the front of the airbox, when sat on the bike....you need to take it off, to be sure that hose is connected!
Old 12-08-2012, 04:40 PM   #20
williamhbonney
williamhbonney's Avatar
Motorcycle: 97 gsxr 750
What is that brown stuff all over your motor?
williamhbonney is offline   Reply With Quote
