FI codes turns over will not fire up : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-06-2012, 08:21 AM   #1
vans4455
I just got a 99 gsxr 750 fuel injected model . I road it a few times ran just fine . I went to ride it last night fi light started flashing no start??? Codes where 13-14-21-22-23-24 didn't find a 13 code anywhere so no clue wat that is.. looked over wiring harness from wat I see no cuts rubbing it brakes in the wires , checked plugs none are melted. Disconnected batt put back on fired up for 2 seconds shut off and all codes came back ??? I'm at a loss here, spins over but won't fire up .
vans4455 is offline   Reply With Quote
Old 12-06-2012, 09:02 AM   #2
vans4455
Re: FI codes turns over will not fire up
Codes 13-14-15-21-23 sorry
Old 12-06-2012, 02:57 PM   #3
Maj750
tip over switch, 23
intake air temp, 21
inlet air pressure, 13
throttle position sensor 14
engine coolant sensor 15
check your connectors at the ecu
Maj750 is offline   Reply With Quote
Old 12-06-2012, 04:17 PM   #4
mikesurfr
Motorcycle: K6 GSXR 600
If you're ECU is unplugged it'll turn over and not start... with that many varying codes that'd be the first place I looked. You might be unplugged or have some wires cut/pulled out of the connector.
mikesurfr is offline   Reply With Quote
