Repurposing triples : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-05-2012, 05:47 PM   #1
kungfutree
Motorcycle: 87 GSXR750, 88 CBR600, 03 XR400
Repurposing triples
I was kicking the idea around at work today of taking my triples into a machine shop and having them milled out from 41mm to 43mm. Has anyone tried this and has it worked?
kungfutree is offline   Reply With Quote
Old 12-05-2012, 06:47 PM   #2
ghostrider.1127
ghostrider.1127's Avatar
Motorcycle: few gsx-r
Re: Repurposing triples
and than?
ghostrider.1127 is offline   Reply With Quote
Old 12-05-2012, 07:24 PM   #3
kungfutree
Easier conversion to 17' wheel. Switch from my stock to the 43mm forks, 20mm axle will be an easier swap, and takes some guess work out (I use the search function, half these threads start an idea and then never say what they did as a solution)
Old 12-05-2012, 07:36 PM   #4
SVS
Brofessional Viking Super Moderator
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '03 GSX-R750, '99 SV650S, '84 XL600R
Bad idea - there isn't too much material as it is, removing a mm all the way around is significant. Change to the newer triples instead?
SVS is offline   Reply With Quote
Old 12-06-2012, 03:25 PM   #5
ghostrider.1127
1th gen came with 200 mm between fork legs
2nd gen with trad 43 mm with 205 mm
not enough material
