08 1000 turbo : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Extreme Performance
Old 12-05-2012, 01:21 PM   #1
Race_fiend
08 1000 turbo
What's up everybody. I bought an 08 1000 this summer and it just didn't "do it" for me. So I bought a 28 psi turbo kit. The bike is going to be a daily rider but will be built for top speed. I just have a few questions. Well a ton of them, but i'll start with this one. Do I need to do anything to upgrade my cooling system?
Race_fiend is offline   Reply With Quote
Old 12-05-2012, 02:09 PM   #2
le skid
Re: 08 1000 turbo
Was your last bike a motocross, by any chance?
le skid is offline   Reply With Quote
Old 12-05-2012, 02:12 PM   #3
oldgixxer
dr. og is gonna give mpd his gamma
oldgixxer's Avatar
Motorcycle: '83 GS1100E,'00 turbo Busa,'05 turbo 1K,'09 Busa,John Deere 48" turbo lawn tractor
Re: 08 1000 turbo
Hmmm.....
oldgixxer is offline   Reply With Quote
Old 12-05-2012, 02:46 PM   #4
Race_fiend
Re: 08 1000 turbo
Nope, 06 1000
Old 12-05-2012, 02:48 PM   #5
oldgixxer
oldgixxer's Avatar
Re: 08 1000 turbo
Some details on the engine this is getting bolted onto&who made the turbo kit
Old 12-05-2012, 03:05 PM   #6
Race_fiend
Re: 08 1000 turbo
Holeshot racing out of N. Ireland built the kit. The bulk of it is a GTX30-76 turbo, CP pistons, Carrillo conrods, lock up clutch, heavy duty studs, Motec stand alone engine management.
Old 12-05-2012, 03:15 PM   #7
oldgixxer
oldgixxer's Avatar
Re: 08 1000 turbo
Thats a big turbo,more then likely you will have to cut the radiator which will make it run on the hot side. Good luck with the bike&welcome to the forum
Old 12-05-2012, 03:22 PM   #8
njyork42
Tennessee Hot Pocket Champ
njyork42's Avatar
Motorcycle: 05 GSXR 750
Re: 08 1000 turbo
Not as bad as the thread looked with the first post... Had potential
Welcome to the forum.. Start a build thread of the bike with lotsa pics.
njyork42 is offline   Reply With Quote
Old 12-05-2012, 08:49 PM   #9
Race_fiend
Re: 08 1000 turbo
Cool, thanks guys
Old 12-05-2012, 11:09 PM   #10
HeJason
HeJason's Avatar
Motorcycle: 02 GSXR turbo 1k, 86 GSXR 750 (92 1216 motor), 89 FZR 1000 (1070 motor), 94 GSXR 750 (95 1146 motor), BigBore 00 Busa
Re: 08 1000 turbo
If you like to ride alot, buy a beater bike. Turbo bikes are fine if you leave the boost low and dont mess with them, which never happens. Welcome to the forum, and post some pics
HeJason is offline   Reply With Quote
Old 12-10-2012, 08:00 AM   #11
Race_fiend
Re: 08 1000 turbo
Am I in the wrong forum for this kind of thing? Has nobody here done big turbos?
Old 12-10-2012, 08:27 AM   #12
oldgixxer
oldgixxer's Avatar
Re: 08 1000 turbo
There are a few members here with a vast knowledge of turbocharging,maj750 is one. You asked a cooling question and it was somewhat answered. it would be much easier if you posted some pics of your setup. And out of curiousity why did the shop who put the kit together not inform you of any issues you may encounter?
This forum as a whole is not typically known for anything other than roadracing. There are small sub-forums such as this but for in depth answers to turbo's you should check out suzukihayabusa.org. turbo 1000's are nowhere near as popular as Busa's so that is a set back right there
Old 12-10-2012, 01:18 PM   #13
Race_fiend
Re: 08 1000 turbo
Ok thanks, I appreciate your help. I'll check that site out also. I'm really just in here to see what other people do and have learned.
Old 12-10-2012, 02:46 PM   #14
Maj750
Re: 08 1000 turbo
Your shopping list seems pretty good, valve springs, oil mods, too ?
just having management like Motec says your pretty serious, lots of guys get the turbo kit part good but don't put the same thought into tuning
turbo kit is big but your obviously after big power, planning drags or mile racing ?
get someone with good experiance to build your motor, 1000's are not as strong as busas
and need everything going for them to survive
Maj750 is offline   Reply With Quote
Old 12-10-2012, 07:26 PM   #15
Race_fiend
Re: 08 1000 turbo
The bike is being built for mile racing as well as being a street machine. Yeah this thing is getting the goods throughout or it definitely won't last. I've been shopping around locally for someone who builds the motors for the guys at the drags. I've found a couple guys but am still looking around. The engine guys i've talked to have said about doing the valve springs and not too much more. I talked to the builder of the kit and he eliminates the oil cooler altogether.
Old 12-11-2012, 12:54 AM   #16
E-RACER
E-RACER's Avatar
Motorcycle: 00 Busa-2007 GSXR-1000 turbo 2007 GSXR-1000 nos
Re: 08 1000 turbo
I would say no cooling problem..use water wetter ect and make sure the air is out of the system and take out the thermostat..along with the springs the ti valves are also weak and snap off..a built turbo motor usually consist of H beam rods and turbo pistons and make sure its tuned well..you can also flash the ecu to turn the fan on sooner..
My lil gt28 and cut radiator with the fan coming on sooner and water runs all day long and doesnt overheat..bone stock motor and I drag race it..
E-RACER is offline   Reply With Quote
Old 12-11-2012, 07:38 AM   #17
Race_fiend
Re: 08 1000 turbo
Awesome. Thanks for the advise. Ill add valves to the list as well. Rods and pistons are coming with the kit so it sounds like i'm on the right track.
Old 12-11-2012, 08:44 AM   #18
TeflonTrout
Ass Packer
TeflonTrout's Avatar
Motorcycle: '99 GSX-R750
Re: 08 1000 turbo
...it didn't "do it" for you. If that much rocket doesn't give you the jollies, you must have the crotch of a porn star.
Good luck with the build, it's pretty cool that you want to make it road worthy, too!
TeflonTrout is online now   Reply With Quote
