What tools are needed for all maintenance on 07 gsxr600 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-02-2012, 11:48 PM   #1
Jblaze79
Motorcycle: 2007 GsxR 600
I received no manual with my 07 Gixxer 600 and was wondering what tools I will need for maintenance because I plan on doing everything nyself?
Sent from my iPhone using Motorcycle.com Free App
Jblaze79 is offline   Reply With Quote
Old 12-03-2012, 09:14 AM   #2
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
Re: What tools are needed for all maintenance on 07 gsxr600
You can download the service manual for free at www.servicesmanualsgsxr.com.
I have not found a link to download an owners manual and just bought one at the dealer (less then $15). It does have some useful information that is not in the service manual or hard to find.
Pretty much a basic set of metric tools are all you need. A voltmeter can be handy.
rv6john is offline   Reply With Quote
Old 12-03-2012, 12:53 PM   #3
zvenkruspe
zvenkruspe's Avatar
Metric Allen Keys ranging 3mm-10mm or more
Metric socket set from 6mm-22mm and an extra socket for your axle nut
Metric Wrench set 6mm-22mm
Needle nose pliers bend and straight
Side cutter
Adjustable plumber wrench to get the oilf filter off
Dead blow hammer
Heavy duty grease
Blue Lock tight
Phillips Screw driver
Flat Head screw driver
All just estimates out of my head what I just used to strip my bike naked (platics, Tank, Oil Change) for winterizing.
zvenkruspe is offline   Reply With Quote
Old 12-03-2012, 06:23 PM   #4
TeflonTrout
Ass Packer
TeflonTrout's Avatar
Motorcycle: '99 GSX-R750
Call me crazy, but I've got a stainless steel ruler that I've used the crap out of for my dirtbikes- everything from chain tension to half-ass sparkplug gapping to checking for warping or items otherwise out of true. Not expensive, takes up no space, but surprisingly handy every now and then. I'll be getting one for use on my gixxer when I come home.
Doubles as a light-duty gunk scraper in a pinch. Peel any kind of anti-slip backing off the back before you use it on something hot, like some dumbass kid I once was did. Burning simu-cork and rubber cement stinks.
Just cured 9 years of motorcycling blue balls.
TeflonTrout is online now   Reply With Quote
