gearing/speedo : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 12-02-2012, 07:05 PM   #1
sic81
gearing/speedo
At 5k rpm my speedo reads 59 mph. Is that what he should read stock? It seems like everyone is passing me on the hwy and interstate.
sic81 is offline   Reply With Quote
Old 12-02-2012, 07:07 PM   #2
Re: gearing/speedo
Stock almost all sportbikes are 7-10% optimistic on the speedo
If you have made any gearing changes (common is -1+2) it is likely closer to %15 off
Moto_Joe is offline   Reply With Quote
Old 12-02-2012, 07:20 PM   #3
sic81
Re: gearing/speedo
I still have 16/45 sprockets and brand new stock size tc2s. Using a chart i found im about 1mph off.
Old 12-02-2012, 07:22 PM   #4
Re: gearing/speedo
Id bet it is more than that.
This will fix it for you if need be though.
https://www.motomummy.com/chain-kits...abs-speedodrd/
Old 12-02-2012, 07:28 PM   #5
sic81
Re: gearing/speedo
Well id like for other 600 owners to chime in with what their speedo reads. If the have stock sprockets
Old 12-02-2012, 07:39 PM   #6
Re: gearing/speedo
I have a 600, and have been around these bikes forever. They are all off from the factory, by varying amounts.
Old 12-02-2012, 07:56 PM   #7
sic81
Re: gearing/speedo
So i compared it to the calculation chart and im only off by 1 mph. You say its likely off by more. So if i dis get a speedo corrector what would i go by to set it right? I guess im just gonna have to use my gps.
Old 12-02-2012, 08:00 PM   #8
Re: gearing/speedo
that is I think the way most do. Use a GPS to calibrate it.
Most are 7-10%. So at 60 youd be looking at it reading 64-66mph usually.
But since they read high, I usually just rode as if it was right. EAsier to not get in trouble that way
Old 12-02-2012, 08:02 PM   #9
sic81
Re: gearing/speedo
That is true lol. Mine is prolly 1-3% off i guess.
