Does anybody know what the ring gap is supposed to be when they are in the bores ? The 96-99 Suzuki manual says 0.50mm is the limit but doesn't give a minimum gap. I measured mine approx 3/4 inch up from the bottom of the bore and I can barely get a .10mm feeler in it.
And that would be the latter set of specs I listed, rings squared up and installed approx 1inch in cyl (uou like 3/4) std is:
.10-.25mm, wear limit is. 50 mm
