Wiring harness routing confused : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-30-2012, 04:27 PM   #1
Neovivi
Hi i have a 98 Srad im in the middle of installing a new loom i baught its all wired up working sweet i got a service manual so i can look at the harness routing diagram but my only confusion is in the pic below that i circled if the wires come out that way the tank pinches the wires is this normal or am i looking at this wrong?
Uploaded with ImageShack.us
Neovivi is online now   Reply With Quote
Old 11-30-2012, 04:31 PM   #2
dj_smurph
Motorcycle: 98 600 srad,97 aprilia chesterfield rs125
Re: Wiring harness routing confused
Your looking at it wrong. Those wires come from low down in the frame on mine.
dj_smurph is offline   Reply With Quote
Old 11-30-2012, 04:32 PM   #3
TT750
Motorcycle: 99 750
under the frame and along the engine inside the fairing not between the tank and frame
Old 11-30-2012, 04:35 PM   #4
dj_smurph
^ that
Old 11-30-2012, 04:37 PM   #5
Neovivi
ah ok got it thanks so not pass the carbs it goes down and out the frame right when i removed the old wiring it was passing the carbs but i thaught they would get rather hot and fry the wires possibly? my old loom was butchered thats why i got a new one
Old 11-30-2012, 09:26 PM   #6
TwistedMister
TwistedMister's Avatar
you can get some of the loom casing at the auto parts store and beef it up around the engine and clean up the harness, looks cleaner and keeps the wire from contacting anything hot and melting the wire..
I didn't like how its so close to the radiator so I used some loom casing to insure some air passes between them.
TwistedMister is offline   Reply With Quote
