beating a dead horse. (headlight wire question) : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-30-2012, 12:13 AM   #1
Mr. Heath
Motorcycle: 97 gsxr 600 srad
ive found the problem but now the issue is my electric wiring skills. has anyone ever done or know of a write up on how fix that wiring issue? anything would be greatly appreciated.
Mr. Heath is offline   Reply With Quote
Old 11-30-2012, 12:23 AM   #2
TwistedMister
TwistedMister's Avatar
Re: beating a dead horse. (headlight wire question)
I've seen some just jump it with a heavier gauge, the real way would prolly be to replace the entire circuit so there are no weak spots?
I dunno the real problem though, is it the wire gauge or is the connector just weak?
TwistedMister is offline   Reply With Quote
Old 11-30-2012, 12:51 AM   #3
Mr. Heath
i dunno i think its just a short in the wire but i wire/wires but im not totally sure which wires to jump and i dont wanna just go in and start hacking up the harness.
Old 11-30-2012, 01:38 AM   #4
nemesis119
nemesis119's Avatar
Motorcycle: 2000 gsxr 600
Its gotta be the gauge..i bypassed the connector and it still shorted on the front harness side of the connection
nemesis119 is online now   Reply With Quote
Old 11-30-2012, 02:16 AM   #5
dj_smurph
Motorcycle: 98 600 srad,97 aprilia chesterfield rs125
Combination of rubbish connector and small wiring.
dj_smurph is offline   Reply With Quote
Old 11-30-2012, 09:18 PM   #6
TwistedMister
what you could do is find where the wires plug in at each end then run a 5ft length and jump it, connect it and make sure its not heating up and everything is good that way, if it solves the problem then clip the original wire(s) and run the new jumper(s) as the new circuit, maybe put a fuse in line to be safe if that gets bypassed?
I believe the shop manual has the wiring diagram so you can find out where the wire plugs in where and what color it is, I think there are 2 switches that complete the circuit, on the lift I know theres the high/low
I dunno if the wiring goes to the right side in the harness but UK bikes had the on/off/tail switch on that side so you'll have to figure out with the schematic where the hot wire actually runs?
hard to say if the UK models actually have a different wire harness or if its the same and the switch is the only difference? my guess is its just the switch and the harness's are all the same, so you could plug in a UK right control switch and have the on/off, I know you can on the 99-00 busas so...
