replace clutch cover HELP!! : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Tech Tips & Tricks
Old 11-29-2012, 05:16 PM   #1
tofani
Recently I laid down my 2011 gsxr 1000 and scratched up the clutch cover on the right hand side of the bike. I ordered in a new cover and gaskets and everything and switched out all the parts. When I cranked the bike it had a loud rattle/tick to it. Called the dealership and the service department said to recheck that everything was seated properly. I did that and restarted the bike and the noise continued. I left the bike on for a minute to try and listen for exactly where it was coming from and to see if maybe it needed a minute to re-lubricate everything after draining out all the oil. It ran for a minute then sputtered and cut off and now it won't restart. I need help.
tofani is offline   Reply With Quote
Old 11-30-2012, 09:45 PM   #2
Chugs
Let's ride!
Chugs's Avatar
Re: replace clutch cover HELP!!
Maybe u dropped an alignment pin in the sump? Remove and check your covers pins?
Chugs is offline   Reply With Quote
Old 11-30-2012, 10:51 PM   #3
Bagherra
He Who Touches Himself
Bagherra's Avatar
Motorcycle: 2K2 GSXR750 Y&B, 2006 GSXR1000 R&B (soon!)
stupid question....did you refill with oil?
Bagherra is offline   Reply With Quote
Old 12-03-2012, 10:19 AM   #4
tofani
Yes I refilled with oil and both dowel pins are present and accounted for.
