Yoshimura Ignition Cover - Pipe Plug for Oil Pressure Sensor : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-29-2012, 10:56 AM   #1
Kiro
Kiro's Avatar
Motorcycle: GSXR1000L0, GSXR1000K7, GSXR1100H, GSXR750K, Aprilia RSV4 Factory APRC SE
Hi,
Any picture of the pipe plug used for the oil pressure sensor hole to fit the Yoshimura Ignition Cover will be highly appreciated (in a 750 89 Slingshot and/or 1100 87).
This to give me an idea how it looks like and what can I use instead.
Cheers!
Kiro is offline   Reply With Quote
Old 11-29-2012, 11:27 AM   #2
tonyc9928
tonyc9928's Avatar
Motorcycle: you know the kind. the ones with wheels. I don't care how many wheels. 1 will do.
Re: Yoshimura Ignition Cover - Pipe Plug for Oil Pressure Sensor
just a brass pipe plug I believe. You can get them at Lowes, any NAPA, plumbing supply etc..
tonyc9928 is offline   Reply With Quote
Old 11-29-2012, 04:31 PM   #3
Hootguy
Motorcycle: 89gsxr-rk,(2),,86 GSXR LTD,,86 gsxr-750 rd/blk,,85 GSXR 750,, 96 gsxr 750/rf900,,98 gsxr 750,,99yosh 750 superbike..86 RG500 Walter Wolf,,86 RG500 blue/wht,,
but remember it's most likely metric,,,if you're shopping in the US,,,should be pretty common,,you might check on the caliper pin plugs used of some bikes,,like Hondas,,,,they might be right,,,i seem to remember them being fine threaded metric,,
Hootguy is offline   Reply With Quote
Old 11-29-2012, 04:45 PM   #4
Kiro
Kiro's Avatar
Hootguy, Tonyc9928, thank you very much.
I got this picture, here is the pipe plug and what it looks like a steel or aluminum rod... any clue what was for?
File Type: jpg Yoshimura Ignition Cover Pipe plug a.jpg (45.1 KB, 278 views)
Old 11-30-2012, 06:41 AM   #5
javadog
Yoshimura junkie
javadog's Avatar
Motorcycle: 1986 GSX-R750R, 1986 GSX-R1100, 1989 GSX-R750RR, 1997 GSX-R750, 2001 GSX-R1000, 2001 Bandit 1200S, plus a few others.
Locating dowel for the starter clutch cover.
JR
javadog is offline   Reply With Quote
Old 11-30-2012, 11:00 AM   #6
Kiro
Kiro's Avatar
JR
Thank you very much Jeff.
Is it entirely essential?
Old 11-30-2012, 12:39 PM   #7
javadog
Yoshimura junkie
javadog's Avatar
It is used to locate the drive gear for the starter clutch.
JR
Old 12-03-2012, 03:07 PM   #8
yvil dead
yvil dead's Avatar
Motorcycle: GAG 50, limited ed., RK, W superbike
Originally Posted by Kiro View Post
Hi,
Cheers!
i had to machine a few of them and its a conical thread. you see it clearly when you look at the sensor. i dont remember the thread but i can check if you want
yvil dead is offline   Reply With Quote
Old 12-03-2012, 05:07 PM   #9
Kiro
Kiro's Avatar
Will be highly appreciated
Old 05-11-2013, 12:58 AM   #10
Kiro
Kiro's Avatar
Well, sometimes what seems difficult is not when parts are searched in the right places.
Got the conical pipe plugs for USD 50 cents each. If anyone needs a piece I will be glad to help.
Old 05-11-2013, 06:19 AM   #11
javadog
Yoshimura junkie
javadog's Avatar
So, what thread size did you buy?
JR
Old 05-13-2013, 11:57 AM   #12
yann7/11R
yann7/11R's Avatar
Motorcycle: MotoMartinGixxer1127
so, what thread size did you buy?
Jr
R 1/8 conical BSP
yann7/11R is offline   Reply With Quote
Old 05-13-2013, 04:46 PM   #13
Hootguy
i believe that plug is supposed to be metric...????,,,
Old 05-14-2013, 01:38 PM   #14
yann7/11R
yann7/11R's Avatar
Not metric.
BSP mean for "BritishStandardPipe".
Imperial size with whitworth thread.
https://www.castrads.com/frequently-...are-bsp-sizes/
Old 05-14-2013, 01:42 PM   #15
Hootguy
you mean to tell me that a Japanese bike is going to use a BSP threaded sensor or plug????,,,surprising...
Old 05-14-2013, 03:30 PM   #16
remusr
remusr's Avatar
Motorcycle: GSXR1K5's street & track, GSXR1100G
Google - BSP 1/8 is 9.73mm od/8.57mm id at 28 tpi (0.91mm pitch); metric 10mm comes in coarse(1.5mm) or fine (1.25 or 1mm pitch). Neither metric fine is exactly same but maybe the BSP is really the bodge for 10mm fine?
remusr is offline   Reply With Quote
Old 05-14-2013, 03:57 PM   #17
Hootguy
so whats wrong with just getting the proper metric plug,,,????,,,i can check my spare RK engine,,they come stock with a plug in there so you might be able to get one right from suzuki....
Old 05-14-2013, 04:12 PM   #18
Kiro
Kiro's Avatar
Sensor nipple od is 9.86mm and pipe plug od is 10.01 mm both on the larger conical circumference. Will get later the smaller conical circumference for both. At a glance thread pitch look quite identical.
Old 05-14-2013, 04:23 PM   #19
Kiro
Kiro's Avatar
Do you know a Suzuki dealer in Canada that can supply the item?
Old 05-14-2013, 09:09 PM   #20
Kiro
Kiro's Avatar
There you go Jeff.... thread pitch is the same
