GSXR-600 2nd gear "skip" : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 11-28-2012, 06:33 PM   #1
wayne26
OK.
I'm 54 (still act 25) and have been riding since I was 8.
I have had just about every kind of bike there is and
have broken just about every bone....so I'm not new to this
by any means. I'm taking the chance of getting a bunch of smart
remarks by asking this ....but, here goes.
I had a guy offer me a sharp 03 GSXR-600 today and
while test riding it I noticed it "skipping".......
ONLY ..... in 2nd gear. OK....first thing I thought was that
I didn't get on it good enough in 1st to make the chain slip
on the sprocket(s). So...I tried it again.....and again.
It WOULD NOT slip in 1st gear. I figured somebody had
speed shifted or abused 2nd gear over the years and
that that was the problem. I contacted a friend of mine that was
the service manager of Bush Motorsports in Cookeville Tennessee
for several years and he said that he had seen SEVERAL cases
where people had torn into their engines and
not found anything wrong and it turned out to just be the front
sprocket slipping. WHY IN THE WORLD wouldn't it slip in FIRST ALSO??
Has ANYBODY out there run into this problem and it just be something
as simple as the sprocket....and if so.....explain it to me WHY it won't do it in first gear as well.
Thanks,
Wayne
wayne26 is offline   Reply With Quote
Old 11-28-2012, 06:42 PM   #2
Samantha750
Scandinavian Mod with PMS
Samantha750's Avatar
Motorcycle: Two wheels and goes VROOM, VROOM
Re: GSXR-600 2nd gear "skip"
Might want to take some time and familiarize yourself with the site and where to post. Your first post regarding a 750 was posted in the 1000 forum and this one in anything goes?
Samantha750 is offline   Reply With Quote
Old 11-28-2012, 06:46 PM   #3
mig1289
mig1289's Avatar
Motorcycle: 2001 GSX-R 1000
You can take off the front sprocket cover and check the teeth of the front sprocket to see if any are missing. If that's not the problem then it's a problem internally.
Sent from my thumbs.
mig1289 is offline   Reply With Quote
Old 11-28-2012, 09:04 PM   #4
Chugs
Let's ride!
Chugs's Avatar
I doubt it's the sprocket, i'm gonna say u might be referring to worn shift fork where it slips out of gear???
Chugs is offline   Reply With Quote
Old 11-29-2012, 02:12 AM   #5
Slaki
Slaki's Avatar
Motorcycle: 2007 GSXR 1000
You can check the front sprocket, but is gonna help you nada... Not the problem.
Reason for slipping is the dogs on second gear are worn. You will need to take the engine out, split the bottom end and have the gearbox undercut. While the bottom end is split, check the selector forks and selector drum...
Slaki is offline   Reply With Quote
Old 11-30-2012, 06:37 PM   #6
dan uk
Motorcycle: i hate bikes
What Slaki said. Sounds like the infamous 2nd gear problem.
It's not that bad. Strip it yourself, then take the engine itself into a shop or even do that yourself. Me I took the engine in. Only took then 3 hours to strip out, repair and rebuild. Then the gaskets, potential oil leaks are their responsibility.
Cost me 250 for the bits, 100 for the Labour
Sent from my GT-I9300 using Motorcycle.com Free App
dan uk is online now   Reply With Quote
Old 11-30-2012, 10:43 PM   #7
Bagherra
He Who Touches Himself
Bagherra's Avatar
Motorcycle: 2K2 GSXR750 Y&B, 2006 GSXR1000 R&B (soon!)
hopefully you are somewhat an experienced mechanic, if so, you can have the engine dropped in about an hour. Flip it over, remove lower case and the tranny will be staring you in the face.
Bagherra is offline   Reply With Quote
Old 12-17-2012, 02:30 AM   #8
babe
babe's Avatar
Motorcycle: 2001 GSXR 600, 07 Ninja 250
I bought my k1 cheap because of this. The k1 had this stick in gear problem due to the pin that works with the shift star for the clutch plates. I think in 01 they used a different style star that often jammed and bent the pin which could lock it into 2nd. Anyways, I replaced the pin, a $6 part and while I was in there, I upgraded to a Motion Pro race shift star. Got the bike working beautifully. Shifted well, installed a quick shifter later, now its awesome.
Sent from my DROID4 using Motorcycle.com Free App
babe is offline   Reply With Quote
Old 12-17-2012, 03:21 AM   #9
njyork42
Tennessee Hot Pocket Champ
njyork42's Avatar
Motorcycle: 05 GSXR 750
Originally Posted by wayne26 View Post
OK.
Thanks,
Wayne
I am from Cookeville, TN as well. If it is the front sprocket first gear would also slip..same goes for the clutch.. Sounds like 2nd gear in the trans is shot. Probably a bent shift fork as well. If you want, send me a pm and I can check it out for you some time. Or if you are close to Sparta..you can just take it into Central Motorsports. My friend owns the shop, works almost specifically on sportbikes ,and is by far the cheapest around.
njyork42 is online now   Reply With Quote
