Ape cct issue : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-28-2012, 05:54 AM   #1
Becks18
Becks18's Avatar
Motorcycle: SRAD 600
Ape cct issue
I bought the ape cct for my bike. Went to install it last night but the bolts won't tighten flush to the flange of the APE. I took it out and noticed that the stock flange cct is quite a bit thicker. I am just going to use a couple washers and a lock washer to make it work. Anyone else notice this issue?
Becks18 is offline   Reply With Quote
Old 11-28-2012, 10:24 AM   #2
THE SRADIATOR
Sent Flowers to Algernon
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
Re: Ape cct issue
Yes...use shorter bolts or spacers (washers or nuts)
THE SRADIATOR is offline   Reply With Quote
Old 11-28-2012, 01:10 PM   #3
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
Re: Ape cct issue
You have a 99/00 bike? They updated the CCT and used a longer bolt then on the early SRADs.
GSXR-Freak is offline   Reply With Quote
Old 11-29-2012, 09:53 AM   #4
Becks18
Becks18's Avatar
Re: Ape cct issue
Thanks guys. I do have a 2000. I just cut the bolts and it worked out just fine.
