Welding question? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-27-2012, 03:54 PM   #1
Gixxertj1819
Gixxertj1819's Avatar
Welding question?
I was told that you couldn't weld on the crankcase because it is cast aluminum. Is this true or can it be done
Sent from my iPhone using Motorcycle.com Free App
Gixxertj1819 is offline   Reply With Quote
Old 11-27-2012, 04:03 PM   #2
Ril3y
Ril3y's Avatar
Motorcycle: 2007 GSXR 600
Re: Welding question?
What exactly are you trying to do/what happened?
Trying to repair a hole from a connecting rod and welding a tab aren't the same. Depending on what you have and what happened, I may be looking for a new one..
Ril3y is offline   Reply With Quote
Old 11-27-2012, 04:13 PM   #3
tlee2989
OG's cock is on my mind...always&forever
tlee2989's Avatar
Motorcycle: only dirt for now
cast in itself is hard to weld. its bascially "pot metal" they have a mold poor liquid material into it and let it harden up. it makes a solid uniform product but the problem is that it also has imperfections, dirt, trash, and other impurities that make it hard to weld.
it can be done but its extremely hard with aluminum it has to be clean clean clean and then you have to find a decent enough aluminum welder to do it. aluminum is one of the hardest metals to weld IMO
tlee2989 is offline   Reply With Quote
Old 11-27-2012, 04:39 PM   #4
Gixxertj1819
Awhile back my chain broke and on the crankcase it broke the tabs where the clutch/sprocket cover screws go in. I need to weld more tabs on it
Old 11-27-2012, 04:54 PM   #5
oshweeken
Yaah I know!
oshweeken's Avatar
Motorcycle: 1999 GSXR 750, 2002 CRF450R, 1974 CZ250, 1996 Yamaha Wavebalster
Yes, you can do it! It will most likely not be a pretty or a very strong weld though. You may have to try different rods to see which will work best on the blend of aluminum.
I have welded a cylinder wall that is off a 2 stroke, completely saturated with oil, ground out a V and then filled it. The weld is holding (not pretty) and leak down test shows no leak, but through a small pin hole I have some oil leaking out when it's running at 13K RPM.
oshweeken is offline   Reply With Quote
Old 11-27-2012, 05:11 PM   #6
Iloveurmommy
Iloveurmommy's Avatar
I welded those tabs on my 02 600, they're not that bad. Just do a very good prep job and if the motor in a running bike, remove the battery so u don't fry the electricals.
Iloveurmommy is offline   Reply With Quote
Old 11-27-2012, 05:44 PM   #7
dj_smurph
Motorcycle: 98 600 srad,97 aprilia chesterfield rs125
Find an aluminum welding specialist. The side stand bracket snapped off the frame on my aprilia. Got recommended someone by three different people. He done a perfect job. He used a welders battery isolator so he didn't need to remove battery.
If your in north London check out Laurie at Bunns Lane welding. When you talk to him you realise he weld not for money but because he can.
dj_smurph is offline   Reply With Quote
Old 11-27-2012, 05:47 PM   #8
ccmhunt
Carb Ninja
ccmhunt's Avatar
Motorcycle: 96 GSXR750, 07 CBR1000RR
aluminum can be welded just fine, I have a friend who can weld tin foil I think... surround yourself with talented people.
ccmhunt is online now   Reply With Quote
Old 11-27-2012, 05:50 PM   #9
Apok
Motorcycle: '03 GSXR1000, '88 GSX 1100F, '92 GSX 1100F
Be careful who you surround yourself with, some peoples talents can drive you insane...
Apok is offline   Reply With Quote
Old 11-27-2012, 05:58 PM   #10
ccmhunt
Carb Ninja
ccmhunt's Avatar
Terry, did you notice where I gave you props in my cam degree how-to?
Old 11-27-2012, 11:12 PM   #11
Armi
Superbike Champ
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
How much did you get charged DJ.....I had my oem screen brace welded, when I didn't know where to get stuff from and was charged £40!!!
I could've bought a new one at that price!!!
Armi is offline   Reply With Quote
Old 11-28-2012, 12:07 AM   #12
TwistedMister
TwistedMister's Avatar
and unplug the ECU! maybe the clock too?
TwistedMister is offline   Reply With Quote
Old 11-28-2012, 12:47 AM   #13
dj_smurph
£30. Was done in an hour and he gave me an aluminium grinding disc so I could fit the side stand back perfect. But that wasn't straight forward welding. He is a genius welder.
Old 11-28-2012, 12:51 AM   #14
QRYPTYQ
good advice for tig welding
QRYPTYQ is offline   Reply With Quote
Old 11-28-2012, 12:52 AM   #15
dj_smurph
Didn't have to the isolator done its job. I have watched him do the same on cars and vans. This guy has forgotten more stuff about welding then most have ever learned.
He still welds because he can. He probably earns £10000 a month in rent from the units he owns. The guy is a legend in north London. When you ask around and three different people say him. One works as a mechanic,one is a bike riding instructor and the other is a guy building a single swing armed fire blade street fighter.
Old 11-28-2012, 12:54 AM   #16
dj_smurph
Oh this guy can mig aluminum like its steel
