CTEK XS 0.8 Charger : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-26-2012, 11:35 PM   #1
Roeland.Vlok
Motorcycle: GSXR 750 k6
CTEK XS 0.8 Charger
I bought a CTEK XS 0.8 charger yesterday to charge or condition my bike battery. When I connected the charger it went through STEP 1 and 2 within minutes. It was running in STEP 3 for a few hours and then switched over to STEP 4 and then STEP 5.
Why did it go through STEPS 1 and 2 so quickly? Is it because the battery is still fine and close to 80% of charge capacity? How long does the Desulphation (STEP 1) usually take?
Any advice would help! Thanks!
Roeland.Vlok is offline   Reply With Quote
Old 11-27-2012, 05:47 AM   #2
Minibull
Viking Foreign Affairs Attaché
Minibull's Avatar
Motorcycle: 1998 GSXR 750
Re: CTEK XS 0.8 Charger
I've used a smaller Ctek one (like yours IIRC) and also one of the bigger ones for car/bike/boat batteries. I always leave it hooked up if I can.
If the bike has been run recently, I find it jumps through to maintenance fairly quickly. I did once put a really hammered battery in and it spent a while going through the first couple of stages though. Left it overnight to find it on the maintenance setting in the morning, and all was good with the battery
Don't worry about it, it's doing its job fine
1998 GSXR 750: Full Titanium Yoshimura Tri Oval exhaust, K&N Filter, A.P.E MCCT, Factory Pro case covers, Goodridge Braided Steel Lines, K7 Radial Master Cyl, FP Levers, Yoshimura Billet Pillion pegs.
To do: Power Commander, Suspension work...
Minibull is online now   Reply With Quote
Old 11-27-2012, 10:30 PM   #3
Roeland.Vlok
Thanks Minibull!
Checked it yesterday after work and it was on the maintinance step. Will run the bike tomorrow and Friday to work as usual. Seems like the charging circuit is going to shite, but will test it during the weekend.
You guys from NZ are always friendly and you CAN play rugby!
Thanks again!
