re-tapping fairing bolt holes : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 11-25-2012, 07:21 PM   #1
5.0snake
Guys, some bolts dont thread properly into the fairing bolt holes and I want to cut new threads in the holes. Problem is I dont know what size tap I need to use. I just purchased a craftsman tap and die kit, metric, comes with 4mm x .7, 4mm x .75, 5mm, 6mm, 7mm and 8mm and a few others as well.
Any suggestions? I dont wanna tap the hole to large and be screwed so thanks for the help.
EDIT: Guess I should mention I am re-tapping the right and left side fairing bolt hole closest to the rear tire and the two fairing bolt holes furthest to the front in the middle of the bike by the turn signals. If that makes sense...if not, I can take photos.
5.0snake is offline   Reply With Quote
Old 11-25-2012, 07:43 PM   #2
HAZDADDY
HAZDADDY's Avatar
Motorcycle: 2009 GSXR 1000, 2006 Busa-sold, 2006 cbr 600- sold
I would find out whatever size it is now, get the same size tap and just run it in a few times. Blow the hole out and make sure there's no chips in there. See if that works before u go tapping the holes a different size.
Sent from my SCH-I535 using Motorcycle.com Free App
HAZDADDY is online now   Reply With Quote
Old 11-26-2012, 06:43 AM   #3
600k2
It's a Jersey thing
600k2's Avatar
Motorcycle: 600k2
Re: re-tapping fairing bolt holes
M6 X 1.0 going from memory. Compare the tap to the bolt and put the threads together and see if they match.
like this
Good tap and die sets come with a thread pitch gauge. You can measure the diameter of the treads to get the size.
600k2 is online now   Reply With Quote
Old 11-26-2012, 01:41 PM   #4
wrenchdude
wrenchdude's Avatar
Motorcycle: 04 Gsxr 1k
+1 on the method above. Also +1 on the thread pitch gauge..You didnt say why you are cutting new threads for your fairing bolts. Are they crossthreaded or are the threads gone to the point the bolt wont get tight? If the bolts wont get tight, cutting new threads wont do any good because there isnt enough material there to cut threads into. If this is the case, you can drill the holes and helicoil them. Helicoil kits can be bought at your local auto parts store, but they are not cheap.
Hope this helps.
wrenchdude is offline   Reply With Quote
Old 12-03-2012, 04:44 PM   #5
5.0snake
Hope this helps.
My reason for re-cutting the holes it due to the fact that I believe the threads to be damaged somehow. When trying to screw in the bolt in, it will screw in about 1/3 of they way before it stops and then feels like the threads are fighting against each other and the bolt wont go any further with out doing more damage.
Thanks for the good advice.
