Impact of Throttle Position Sensor adjustment : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-25-2012, 07:17 PM   #1
rick450d
Motorcycle: GSX-R750 K6
Question Impact of Throttle Position Sensor adjustment
Hi,
I just resolved the "herky jerky" issue I had by adjusting the TPS, moving the indicator (-C00) until it just moved into the top selection.
The beast has been tamed and everything is smooth through the range.
A couple of weeks ago I had a power commander III custom map created so I am now wondering how much this adjustment would have impacted on the custom map and if it would make enough difference to justify getting another map created?
I am also unsure what other impacts this change would have.
Is there any type of problem associated with moving the indicator to the top posing
-Run Richer?
-Less fuel economy?
-Excellerated wear or failure of parts (Fouling plugs etc)?
The issue occurred when riding at low speeds and when rolling off the throttle in top gear there was a point at around 4k rpm where I think the injectors were cutting in and out.
Bike Details:
GSX-R 750 K6
Micron Slip-On
K&N Filter
PCIII
Custom Map
Thanks Guys.
rick450d is offline   Reply With Quote
Old 11-25-2012, 07:47 PM   #2
MacBayne
anyone else smell poop?
MacBayne's Avatar
Motorcycle: K6-600 track, K9-750 white/silver street.
Re: Impact of Throttle Position Sensor adjustment
it will make a difference, yes. it will be retardedly minute though. don't worry about it.
MacBayne is offline   Reply With Quote
Old 11-25-2012, 08:55 PM   #3
TheCunningMan
TheCunningMan's Avatar
Motorcycle: 750k6
You may need to resync the PCIII with your TPS.
TheCunningMan is offline   Reply With Quote
Old 11-25-2012, 09:23 PM   #4
rick450d
Yeah I reset the throttle position from within the PCIII if that's what you mean?
Thanks
