Do I have the rotor lined up right? Valve adjustment. : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-24-2012, 09:55 PM   #1
ANDRASTA
Motorcycle: 1990 GSXR 1100
Hey guys,
I have the repair manual but on the photo in the manual its kind of hard to make out. Do I have the mark set right to do the valve check? I have the line perpendicular to the pick-up.
ANDRASTA is online now   Reply With Quote
Old 11-24-2012, 10:24 PM   #2
86boiler
Re: Do I have the rotor lined up right? Valve adjustment.
thats how i did mine! looks good to me! good luck
86boiler is online now   Reply With Quote
Old 11-25-2012, 02:33 AM   #3
long_av8r
Oiler Mod
long_av8r's Avatar
Motorcycle: (3) 1st gen 750's; (2) 1st gen 1100's; 90 7/11; 05 RMZ-450; 83 Honda CB1000C; 78 Yamaha DT 175E; 89 HD 883 Sporty; 98 KX250; 85 ATC 125M; 04 Polaris Predator 500; and a few kids quads.
Yes, stick a screwdriver in the plug hole to check. When the screwdriver reaches its top, that's TDC and those marks should line right up.
long_av8r is offline   Reply With Quote
Old 11-25-2012, 08:59 PM   #4
ANDRASTA
How would this differ in relation to an advancer?? Would you line it up the same?
Anyone have pics of an advancer installed??
Old 11-26-2012, 10:24 AM   #5
javadog
Yoshimura junkie
javadog's Avatar
Motorcycle: 1986 GSX-R750R, 1986 GSX-R1100, 1989 GSX-R750RR, 1997 GSX-R750, 2001 GSX-R1000, 2001 Bandit 1200S, plus a few others.
There shouldn't be enough duration in the cam profiles that a few degrees, such as the amount a typical advancer provides, would make any difference. All you are trying to do is ensure that the adjuster in question is over the base circle of the cam when adjusting it. If you're worried about it, offset the adjuster by the amount of the advance it provides. It won't matter but it might make you feel better.
JR
javadog is online now   Reply With Quote
