I got a new leak : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-24-2012, 04:37 PM   #1
Monolith
Monolith's Avatar
Motorcycle: 1996 GSX-R750, 2000 GSX-R600
I got a new leak
So it seems ive developed a leak on this hose. Appears to be coming from the hose mount or tube binding... Or even possibly a run off of my leaking side mount dampner thou it seems very unlikely(I need to rebuild it someday). Going to clean it off with some isopropyl and check to see if it comes back after a short ride.
Was wondering if anyone might know the TRQ for it and if I should be alarmed.
Also what is it even for or called? Im still searching threw part listings tryin to find out.
Thnx for any insight!
1996 Srad 750 - Full Hindle, DJ kit(ccmhunt ) soon Yosh MJN kit, Toby Side mount dampner, Ohlins Rear, AirTech catch tank, Pro-Tek rearset adapters, Brembo Rotors, Braided brake lines,
2000 Srad 600 - Full Hindle, Yosh MJN kit (TY ccmhunt ) , Toby Side mount Dampner, Pro-Tek tripple clamp, 8kHids 4x blue ccfls
Monolith is online now   Reply With Quote
Old 11-24-2012, 04:47 PM   #2
TT750
Motorcycle: 99 750
Re: I got a new leak
look on the ronayers parts fish under the cylinder page..
Old 11-24-2012, 04:47 PM   #3
TT750
Motorcycle: 99 750
Hose comp,cyl h
11282-33e00
Old 11-24-2012, 04:49 PM   #4
ccmhunt
Carb Ninja
ccmhunt's Avatar
Motorcycle: 96 GSXR750, 07 CBR1KRR, ZX7/9RR F-USA AMA
That's pretty common. It could either be from the crush washers and bolt, or the pressed on fitting.
Some people go to hydrolics shops and have superior hoses fabricated.
ccmhunt is online now   Reply With Quote
Old 11-24-2012, 04:50 PM   #5
Armi
Superbike Champ
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
I think I need a crush washer then...
Armi is offline   Reply With Quote
Old 11-24-2012, 04:53 PM   #6
TT750
Motorcycle: 99 750
you need to post some pics is what you need to do.. or is it we need you to do..
Old 11-24-2012, 04:55 PM   #7
TT750
Motorcycle: 99 750
in the pic it kind of looks like its comming out of the swag on the bango fitting but it may just be the angle of it.
Old 11-24-2012, 05:00 PM   #8
Monolith
Monolith's Avatar
Awsome TY guys, you rock!
Old 11-24-2012, 05:04 PM   #9
TT750
Motorcycle: 99 750
if you get a line made at a hydraulic shop make sure it is well flushed.. as you don t want any grindings from when they cut the line to make its way into the engine. I know the hard way.. my bro put lines on my 73 charger with a 340 to hook up a remote oil filter because the header made it impossible to use the filter in stock location. i had to get the crank turned and all new bearings. major pain
Old 11-24-2012, 09:12 PM   #10
Monolith
Monolith's Avatar
If it ends up that I have to replace it I'll just purchase a new oem one unless its advised that I should do otherwize.
Old 11-24-2012, 09:17 PM   #11
ccmhunt
Carb Ninja
ccmhunt's Avatar
Stock is fine, let me know if you want me to price one for you, I buy cheap, will sell at my cost.
