Headlight issue : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 11-24-2012, 08:57 AM   #1
bullfrog521
bullfrog521's Avatar
Motorcycle: 03 Suzuki GSX-R 600 (K3)
Headlight issue
so i figure this is a(n) recurring question...have low beam issue of not coming on...i've changed the whole switch assembly, checked fuses, and changed light bulb itself with no help of it working...i started bike one morning and it came on then went to high beam and back to low beam and it wouldn't work...is there anything else that im not getting that could be the source of the problem...
bullfrog521 is offline   Reply With Quote
Old 11-24-2012, 12:46 PM   #2
dan uk
Motorcycle: i hate bikes
Re: Headlight issue
I'd get the old multi-meter out and narrow the problem down, old fassioned process of elimination. Start with the light female 3-prong connector see if you can/can't get the problem there and work back through the connectors until you don't.
dan uk is online now   Reply With Quote
Old 11-24-2012, 02:48 PM   #3
bullfrog521
Re: Headlight issue
thats what i was wondering if it would be in other side of connector since i replaced the switch completely..in that case could it be the whole wiring harness issue ive looked at fisch and that seems only way to solve it its in other end of wiring
Old 11-24-2012, 02:55 PM   #4
gixerhp
gixerhp's Avatar
Motorcycle: Hayabusa
Re: Headlight issue
What bulbs are you using on the bike?
gixerhp is offline   Reply With Quote
Old 11-24-2012, 03:03 PM   #5
bullfrog521
Re: Headlight issue
H4...funny thing was twice now ive started bike and low beam would be on but soon as i switch to high then back its out ive heard that some ppl try different bulbs and resolve issue
Old 11-29-2012, 10:20 PM   #6
deanoderek
Re: Headlight issue
Hey could someone clear something up for me please...... I drive a GSXR K2 600. I was looking at a H7/H9 HID Headlight Kit for a Suzuki GSXR 600 2002 on ebay i was going to buy to install on my bike......
Firstly will this kit work?? and secondly in reading allot of forums about k2 headlight problems im reading that on low beam both lights should be on ......
on my bike when low beam is switched the left light is on and when i switch to high beam the one on the right comes on meaning my two lights are on....... Is this wright ???
deanoderek is offline   Reply With Quote
Old 11-29-2012, 10:26 PM   #7
nemesis119
nemesis119's Avatar
Motorcycle: 2000 gsxr 600
i THINK yours is H7...not 100% on that..but look into that and see if that helps at all :
nemesis119 is offline   Reply With Quote
Old 12-01-2012, 02:27 AM   #8
OAB750
OAB750's Avatar
Motorcycle: GSXR1000 K2
Re: Headlight issue
OP - check the condition of the connector blocks for the wiring. Known weakspot.
OAB750 is offline   Reply With Quote
Old 12-01-2012, 08:41 AM   #9
Iloveurmommy
Iloveurmommy's Avatar
When sitting on the bike, down under the right ram air duct there is a bunch of harnesses. I don't remember which one of them it is but one is for the headlight. Find which one it is and clean it. That is where all my headlight issues came from.
Sent from my iPhone using Motorcycle.com Free App
Iloveurmommy is offline   Reply With Quote
Old 12-01-2012, 08:47 AM   #10
Iloveurmommy
I just remembered which harness it is. It's a black one with a orange wire being looped back into one side. Hope this helps.
