Temp Sensor : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > Water Cooled Gixxers
Old 11-24-2012, 02:17 AM   #1
Hurls
Motorcycle: GSXR 1100 93
Temp Sensor
Hi all,
I am trying to locate the temp sensor as the temp gauge just stopped working. There are two sensors running into the housing behind the radiator cap (under the tank) Is it one of those? And would the second one be for the fans?
If so, which is which and if not, where do I locate it?
Thanks in advance.
Hurls
Hurls is offline   Reply With Quote Quick reply to this message
Old 11-24-2012, 11:30 AM   #2
Sabba
Supersport Racer
Sabba's Avatar
Motorcycle: '89 CBR 600 (SOLD), '93 GSXR 750 (SOLD), '04 GSXR 600
Re: Temp Sensor
Hi Hurls,
You are correct. The smaller of the two is for the temperature guage (pic). It has a small metal tab on it that is easy to break off...
If you take it out, be sure to have some teflon tape to seal the threads.
The larger one is to trigger the fan.
Sabba is offline   Reply With Quote Quick reply to this message
Old 11-24-2012, 09:00 PM   #3
Hurls
Re: Temp Sensor
Great advice thanks!
It think the cause of the issue is that the tab was broken off by a previous owner and fixed by a bit of dodgy solder work and some silicon.
Might be tome to try and locate a new one.
Cheers
Hurls
Old 11-26-2012, 10:56 PM   #4
Sabba
Supersport Racer
Sabba's Avatar
Re: Temp Sensor
That will do it...
I snapped off mine a long time ago. Got a new (used) one off eBay for $10...the 1100 and 750 use the same part for this.
Search this Thread:
Advanced Search
