pulling dents in frame? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-23-2012, 08:44 PM   #1
SwoleLikeGoku
Motorcycle: 98 GSXR 750
I have a 97 750 that has a salvaged title. I want to take the bike to have a pre salvage inspection done so it can be street legal. The frame has 2 good sized dents in it. One on each side. What is the best way to repare these dents? I heard of tack welding a piece on and pulling them out. I cant just fill it in with body putty because one dent is right over the access hole for removing the carb.
SwoleLikeGoku is offline   Reply With Quote
Old 11-23-2012, 10:27 PM   #2
justfaster
justfaster's Avatar
For the dent at the access hole, you could try a slide hammer with a L-shaped attachment. The other dent, they make slide hammers that you weld a stud on to dent and slide hammer it then grind off the stud. Not sure if they make aluminum ones thou.
Sent from my iPhone using Motorcycle.com App
justfaster is offline   Reply With Quote
Old 11-23-2012, 10:31 PM   #3
THE SRADIATOR
Sent Flowers to Algernon
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
Re: pulling dents in frame?
With dents as BIG as you are describing, are you sure your frame is not bent?
I have frame specs in another post and a clean titled frame if need be as well.
THE SRADIATOR is online now   Reply With Quote
Old 11-24-2012, 12:34 AM   #4
Armi
Superbike Champ
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
^^^ Thats the option i'd go for, unless your name is Destructo.
A dent on the frame here in the UK, is a write off....for a good reason, no doubt!!!
Armi is online now   Reply With Quote
Old 11-24-2012, 08:53 AM   #5
Dented frame is garbage
Moto_Joe is offline   Reply With Quote
Old 11-24-2012, 08:55 AM   #6
ccmhunt
Carb Ninja
ccmhunt's Avatar
Motorcycle: 96 GSXR750, 07 CBR1000RR
What he said^^^^^, or you could consult Sherwin on it........
ccmhunt is online now   Reply With Quote
Old 11-24-2012, 09:00 AM   #7
TT750
Motorcycle: 99 750
wonder where sherwin is now lol
Old 11-24-2012, 09:42 AM   #8
THE SRADIATOR
Pulling his ummm, errr... dents?
Old 11-24-2012, 10:58 AM   #9
SwoleLikeGoku
yea this bike was actually my track bike last year. Im pretty sure the frame is strait cause i put a different engine in it with no problems lining up all the mounts at all. The dents arnt that big. I acutally took the good frame that was polished off this 97 bike and used it on my 98 that has good fairings and chrome wheels. So my 98 is my good street bike. Now this 97 has the dented 98 frame. It has potential to be a good street bike if i could fix the frame. I will look into some tools to pound these dents out as much as i can, or maybe find someone in the St.Louis area who can get them out for me.
Old 11-24-2012, 11:44 AM   #10
THE SRADIATOR
You can, depending on the size/location of the dent, drill a hole from the inside and drive the dent out.
Old 11-24-2012, 12:15 PM   #11
SwoleLikeGoku
thats true. I guess then you wouldnt be able to see the holes. If i keep them small it shouldnt degrade frame strength. they already have some holes.
Old 11-24-2012, 12:24 PM   #12
justfaster
justfaster's Avatar
Or if the frame is straight like you say and your creating a street fighter you could cover them with those carbon fiber frame covers, just a idea.
Old 11-24-2012, 02:29 PM   #13
SwoleLikeGoku
actually when i bought the bike it did have a chrome frame cover. Just dont think that would pass the rebuilt inspection. Honestly i just want this thing to pass so i can fix it up and sell it to buy a salvaged k6 1000 for the track.
Old 11-24-2012, 11:32 PM   #14
GSXR Maori
Bumbadoo
GSXR Maori's Avatar
Motorcycle: GSXR1000K6 GSXR1000K1 GSXR750K2x2 GSXR750K1 GSXR75097x2 TLR99 Yami TT600 TT500 WR500 XR500x2
I've repaired a couple of frames that had the dents you speak of. If the dents are accessible from the inside then you can tap them out with a hammer and a drift with a blunt end. Don't use something sharp like a screwdriver. If they're larger you may have to cut the inner out to gain access then have it welded back in after the repairs are finished. You'll need some panelbeating (bodyman I think is the US term) skills to dress the outer and file finish it if you're not painting it. Another tip with Aluminium, don't use a body file too much as the material is soft and will disappear fast. 80-120 grit sandpaper on a sanding board does the trick. I was a panelbeater for 13 years.
One day I'll get round to it.
GSXR Maori is online now   Reply With Quote
Old 11-25-2012, 12:47 AM   #15
tigertim20
tigertim20's Avatar
Motorcycle: 2001 R1, 2004 GSXR1k
this would be my concern too. I would suggest getting an engineer to measure the frame first and make sure she is all straight before you do anything else.
I would be concerned about using a frame that has had dents repaired in it, but thats just me - seems like there are a lot of pretty good dudes on this forum and I reckon you might have less hassle using them to network and locate another frame at a 'mates rates' kinda price
tigertim20 is offline   Reply With Quote
Old 11-25-2012, 01:46 AM   #16
speedy sie
speedy sie's Avatar
Motorcycle: gsxr k1 1000 184.5 rw bhp ex race bike day time mot project and xro7 project build
i will be getting a work xro6 frame that has large dent in,frame is true damper bracket is pushed in and when i say pushed in ,you will see when i go to pick it up.
speedy sie is offline   Reply With Quote
Old 11-30-2012, 08:20 PM   #17
SwoleLikeGoku
thanks. This is good info. Sounds like you know what your talking about. I realy just want this bike to pass the inspection so I will probably just paint it when done.
Old 11-30-2012, 11:52 PM   #18
hamill12
hamill12's Avatar
Motorcycle: gsxr srad 1000. rd 500 ypvs
Mario is da man of dents!!!!
hamill12 is online now   Reply With Quote
Old 12-01-2012, 12:07 AM   #19
Just Saw-zall the dented areas out. But sure to also cut and equal sized opening on the back side of the frame spar to equalize the air flow. This is increase airflow to the engine and make the bike more "aero".
Shervin can help.
SPL170db is offline   Reply With Quote
Old 12-01-2012, 01:35 AM   #20
GSXR Maori
Bumbadoo
GSXR Maori's Avatar
Fuck'n Mario.
