Idle mixture screw o-ring : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-23-2012, 08:25 PM   #1
AlanDog
This post seems to describe issues I'm having:
http://www.gixxer.com/forums/showpos...3&postcount=37
So I don't get what the idle mixture screw o-ring is for. I see the fuel passage going into the screw passage and how screwing the screw in will stop fuel flow into the throttle body. So is the o-ring simply to prevent fuel from leaking out the threads of the screw, or air leaking into the circuit from the screw threads?
It's just that this posting makes the o-ring sound so critical. With so much thread surface it seems very little air could get sucked in.
AlanDog is offline   Reply With Quote
Old 11-23-2012, 08:59 PM   #2
javadog
Yoshimura junkie
javadog's Avatar
Motorcycle: 1986 GSX-R750R, 1986 GSX-R1100, 1989 GSX-R750RR, 1997 GSX-R750, 2001 GSX-R1000, 2001 Bandit 1200S, plus a few others.
Re: Idle mixture screw o-ring
As the post says, the o-rings prevent air leaking into the circuit from the screw threads.
JR
javadog is offline   Reply With Quote
Old 02-15-2013, 12:50 PM   #3
frasermanx
frasermanx's Avatar
Motorcycle: BMW R80st, GSXR 1990 1100, 1986 750
I measured 0-rings from my VM29SS and they are the same as BST36.
O.D. .200"
I.D. .113"
WIDTH .040"
JET .117"
MAYBE THIS WILL HELP ?
frasermanx is offline   Reply With Quote
Old 02-15-2013, 12:56 PM   #4
86boiler
You could try running it without the o ring and it may work. I wouldn't try it because taking the carbs back off if it doesn't work sucks !
86boiler is offline   Reply With Quote
