Charging problem : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 11-22-2012, 06:27 PM   #1
Goodwill3
Charging problem
2001 GSXR 600 new stator, r/r, battery and wire harness from stator to r/r. It only pulls about 12.15 v at 5k rpm and around 11.89 at idle. I can ride for about 6 miles and then the battery goes dead. Charge the battery again and the same things happens. I've triple checked all connection and all wires. I'm a rookie and I can use some help.
Goodwill3 is offline   Reply With Quote
Old 11-22-2012, 09:13 PM   #2
CrickiKaze
CrickiKaze's Avatar
Motorcycle: 2008 GSXR 750
Re: Charging problem
Take a look at this, might help.
http://www.gixxer.com/forums/showthr...061&highlight=
Funny I was just looking at it.
CrickiKaze is offline   Reply With Quote
Old 11-23-2012, 12:30 AM   #3
Slaki
Slaki's Avatar
Motorcycle: 2007 GSXR 1000
Replace rectifier....
Slaki is offline   Reply With Quote
Old 11-23-2012, 06:19 AM   #4
Knight2211
Unstable SuperMod
Knight2211's Avatar
Motorcycle: 92 GSX-R 750R Liquid
He said he already did. Not saying that it isn't bad again though.
Knight2211 is online now   Reply With Quote
Old 11-23-2012, 06:48 AM   #5
CrickiKaze
CrickiKaze's Avatar
Replaced the stator and r/r at the same time?
Old 11-25-2012, 02:09 PM   #6
Goodwill3
Yes I replace them all at the same time. R/r started smoking when I was testing everything out. So I bought all new including wire harness from stator to r/r. I did some more tests yesterday and it appears that I got a defective stator. Contacted the place I bought everything from and they are rushing me out a new stator and r/r.
Old 11-28-2012, 02:32 AM   #7
yellowgixxr
Do a search for Mosfet regulator rectifier or follow the link. I have one if these and their awesome. Also I read somewhere that the zip ties on a stator can cause them to smoke out early - thus guy reckoned he removed them (carefully!!) and had no issues. Anyway, do some reading and have a go. I had similar charging issues, replaced the reg rec and did the stator thing, new wires and no issues since.
Good luck.
yellowgixxr is offline   Reply With Quote
