How to touch up swingarm : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-22-2012, 01:25 PM   #1
enzoalex
How would you guys suggest touching up a small mark on a swingarm, about the size of a coin, on my 2006 GSXR 750?
It's worn through the paint and has slightly corroded the metal. I was thinking of spraying it but I can't think of any paint that would match the swingarm.
enzoalex is offline   Reply With Quote
Old 11-23-2012, 04:37 AM   #2
TOEJAM
Ditchard the High Maintenance Squirrel
TOEJAM's Avatar
Motorcycle: 06 R1 Raven; '07 Ducati 1098S; '08 Triumph Sprint ST; '09 Triumph 675; '10 Yamaha R6; '13 Aprilia RSV4 APRC
Re: How to touch up swingarm
Personally, i would clean it with alcohol and then hit it with a black paint stick or one of the little bottles of touch up paint that come with the brush. Hell, i have even used a magic marker before.
TOEJAM is offline   Reply With Quote
Old 11-23-2012, 09:14 AM   #3
2movethesoul
2movethesoul's Avatar
I used a small paint brush to touch up one of the holes that my chain guard was mounted to.
Any flat black will blend in nicely, I'll post a picture of the stuff I got when I get home later this evening. 99% match.
2movethesoul is offline   Reply With Quote
Old 11-23-2012, 09:38 AM   #4
enzoalex
Cheers for the replies guys, I'd appreciate a picture of what you used so I know I get the right kind of thing.
Here are some pictures of what i want to sort out for reference:
Old 11-23-2012, 09:53 AM   #5
2movethesoul
You can touch it up, but that won't help the corrosion much...
I personally would take the swingarm off, sand blast it and get it powder coated.
Yes, I'm picky like that! lol
Old 11-23-2012, 10:38 AM   #6
enzoalex
Ha, bit extreme. What if I rubbed the salt off with sandpaper and then touched it up.
But I don't want to make it any worse than it is.
Old 11-23-2012, 10:41 AM   #7
Knight2211
Unstable SuperMod
Knight2211's Avatar
Motorcycle: 92 GSX-R 750R Liquid
That's not salt, that's the remains of your swing arm.
Knight2211 is offline   Reply With Quote
Old 11-23-2012, 10:43 AM   #8
enzoalex
? It is corroded slightly, the paint is bubbling a bit around it
Old 11-23-2012, 10:46 AM   #9
Knight2211
Unstable SuperMod
Knight2211's Avatar
Yes, think of it as "Rust"
Old 11-24-2012, 06:51 PM   #10
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
Clean the aluminum down to bright shiny metel with a stainless brush or aluminum oxide paper. Do not use any steel or iron abrasives (iron oxide paper, etc) It imbeds in the aluminum and causes future corrosion problems.
Treat the clean metel with alodine if you can get it. Zinc chromate primer is the best, but I guess there were too many two headed frogs so it is no longer sold as far as I know. There are also "zinc rich" aluminum primers that work well.
The color is basically black, the key to a good appearance is the texture. Look for satin or semi-gloss black. I think you will find it to be a very close match.
rv6john is offline   Reply With Quote
Old 11-25-2012, 04:16 AM   #11
enzoalex
Seems like good advice,
thank you, i'll give it a go
Old 11-25-2012, 04:15 PM   #12
Tater Tot Wee Woo
I am a tater tot; young, not stout. Here is my baby face whoa did a pube just sprout?
Tater Tot Wee Woo's Avatar
Motorcycle: 2007 GSXR 600
Mine is marked up too from my boots rubbing on it from the track. Once you learn to live with it, it's not bad. Plus, most people won't really notice that.
Tater Tot Wee Woo is offline   Reply With Quote
