GSX-R Engine in Formula Racing Help : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-21-2012, 08:46 PM   #1
awegrzyn
I just purchased a Formula 1000 and it runs a Suzuki GSX-R1000 engine. As of now I know very little about the engine, so I'm going to ask obvious questions.
I need help with the following:
1. What year is my motor? Here is the number off the engine: T711-131024
2. Can you guys suggest a good repair manual or good spec sheet for the engine.
3. What is the best racing engine oil and how much? On the side of the plug it says 3000ml (3.17 US qt). Is that the amount of oil?
4. What's the best/light weight oil filter?
5. I'm assuming the transmission and the engine use the same oil from the same oil pan.
6. Any specific lubricant for the chain?
7. Does anyone cool the engine with water and water wetter only?
8. Should I stick with the original spark plugs, or there is something better out there?
9. Is there an online store for OEM parts you guys would recommend?
Thanks in advance.
awegrzyn is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 09:10 PM   #2
!ThatGuy!
!ThatGuy!'s Avatar
Re: GSX-R Engine in Formula Racing Help
!ThatGuy! is offline   Reply With Quote Quick reply to this message
Old 11-22-2012, 10:29 AM   #3
coopgt1
Rectum Rupticus
coopgt1's Avatar
Motorcycle: 2003 GSXR 750
no answers for you without pics.
coopgt1 is offline   Reply With Quote Quick reply to this message
Old 11-22-2012, 11:56 AM   #4
obc
obc's Avatar
03 or 04 gsxr 1000
obc is offline   Reply With Quote Quick reply to this message
Old 11-23-2012, 12:35 AM   #5
Slaki
Slaki's Avatar
Motorcycle: 2007 GSXR 1000
Find all your answers here:
http://www.servicemanualsgsxr.com/
Slaki is offline   Reply With Quote Quick reply to this message
Old 11-23-2012, 01:43 PM   #6
Jd4oor
I Heart Man Sauce
Jd4oor's Avatar
Motorcycle: 2006 GSX-R 1000 2007 GSX-R 600
Thanks in advance.
1. T711=03-04 GSX-R1000
2. servicemanualsgsxr or scribd.com should have a pdf for the 03-04
3. Up for debate, IMO any bike specific 10W-40 synth or synth blend - I use Suzuki dino juice personally. Yes, a little over 3 qts, use the sight glass to check the level.
4. I use OEM Suzuki filters.
5. Yes and the clutch plates as well.
6. That depends on your chain. Most people (on bikes at least) use 530 or 520 O-ring chains. Use a lube designed for o-ring type chains.
7. Yes I use water wetter in my track bike. Make sure you drain it before winter if your temps drop below freezing.
8. Stick with the OEM NGK CR9 unless your engine is modified and tuned to use something else.
9. Ron Ayers, Oneida Suzuki, Sportbiketrackgear, Motomummy
Jd4oor is offline   Reply With Quote Quick reply to this message
Old 11-23-2012, 02:59 PM   #7
I dont think there is a good way to tell
Manuals can be found in PDF online if you find out what engine it is
Yes. Use an oil that is JASO MA Spec oil. I prefer Amsoil, or Motul 5100
OEM or K&N (I use K&N because of its safety wire nut)
yes
chain lube. I use dupont dry teflon chain lube to combat fling.
Yes. All racers basically do.
Yes. OEM plugs are all you need.
RonAyers.com
Thanks in advance.
Moto_Joe is offline   Reply With Quote Quick reply to this message
Old 11-23-2012, 04:19 PM   #8
Bagherra
He Who Touches Himself
Bagherra's Avatar
Motorcycle: 2K2 GSXR750 Y&B, 2006 GSXR1000 R&B
where are the pix???
Bagherra is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 04:12 PM   #9
awegrzyn
Sorry it took so long, but here it is:
Garage is not mine.
Old 04-23-2013, 04:19 PM   #10
cainyboy
Buggering Pommy Poofter
Motorcycle: Kawasaki ZX9R
Garage is not mine.
Now where is the vid of that thing with it's angry face on?
cainyboy is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 07:01 PM   #11
Bagherra
Bagherra's Avatar
that thing has a gsxr engine in it??
Old 04-23-2013, 07:24 PM   #12
gsxr313
gsxr313's Avatar
Need. Vid. Now.
gsxr313 is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 09:34 PM   #13
awegrzyn
Yes, mine has K4 motor. Guys mostly run the 2007 engine. The class is called Formula 1000 (1000 cc, 1000 lbs). Pretty well liked class, because we use bike motors that can't be open. On top of that we use electronic shifters. Sort of like Formula 1 under budget for middle age guys.
