Re: Power Commander V on 2007 GSX-R 600
will plug up to a 06-07 no problem, everything is similar. plug and play. if you want auto tune option then you will need to weld in a spot for a 02 sensor.
best way to go about it would be to get the pcv, get a custom tune on the dyno for your area, as a base map. Then use the auto tune only when conditions change and you need a quick remap. only way this is beneficial to track days if your racing.. Otherwise just go with the PCV and get a custom tune. an save that $ for parts or gear.
