"Worn" Ignition Switch : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-21-2012, 05:59 AM   #1
Kekoa
Kekoa's Avatar
Motorcycle: '05 600
Wanted to get a new key since the current one, which came with the bike from the factory, was rounded and you'd have to jiggle it to get it to turn. I'm guessing that the previous owner had to have been doing the same for a while as well, making me think that the tumblers might be warped or just old and worn.
My reasoning being that after I got a new key cut to like the factory spare key that the bike came with, it wouldn't turn, even with the jiggles. I did get it cut at Sears, but even the factory spare key was never smooth turning.
I'm thinking of taking the whole ignition into a lock smith to get a key made to the now "worn" ignition, or just getting another key cut at an actual locksmith. Verdict?
Heres a picture of the progession. On the left, the factory spare key, center is the old key, the right is the newly cut key.
Kekoa is offline   Reply With Quote
Old 11-21-2012, 08:24 AM   #2
Re: "Worn" Ignition Switch
blurry picture is blurry, but try lubing the lock first with a graphite lube. Might help.
Moto_Joe is offline   Reply With Quote
Old 11-21-2012, 09:07 AM   #3
600k2
It's a Jersey thing
600k2's Avatar
Motorcycle: 600k2
Take the new key and run it under a wire brush wheel on a bench grinder.
600k2 is online now   Reply With Quote
Old 11-21-2012, 04:24 PM   #4
Kekoa
Kekoa's Avatar
Motorcycle: '05 600
@MotoJoe: Flip phone pictures are only so good. But what do you mean by graphite lube? I thought of greasing it but I don't wanna damage any electronics in it.
Old 11-21-2012, 04:27 PM   #5
clicky
Old 11-23-2012, 10:44 PM   #6
Kekoa
Kekoa's Avatar
Motorcycle: '05 600
UPDATE: Did more "testing" come to realise that even the factory key isn't turning easy either, safe to say the whole thing is just getting worn. I'll try the graphite trick, but if that doesn't work then I'll get another key made, but thins time having it made from the older key.
Old 12-01-2012, 04:32 PM   #7
Kekoa
Kekoa's Avatar
Motorcycle: '05 600
UPDATE: Thanks to moto joe's genius, I did the graphite trick and it worked. Just follow what they explained in the link and you'll be back in action.
http://www.instructables.com/id/How-...e-From-a-Penc/
Old 12-01-2012, 04:43 PM   #8
Crashing Sucks
whiter than whole milk...
Crashing Sucks's Avatar
Motorcycle: K7 GSX-R 1000 (Steet Whore) 2005 Triumph Daytona 600 (Track Whore) K3 Honda RC51 SP2 (Heavywieght Torque Demon)
Lube helps everything
Crashing Sucks is offline   Reply With Quote
Old 12-01-2012, 08:04 PM   #9
cincinnatibodyman
PalinFan88
cincinnatibodyman's Avatar
Motorcycle: 07 1kRR
My locksmith uses wd-40
cincinnatibodyman is offline   Reply With Quote
Old 12-01-2012, 08:17 PM   #10
davidhar
doffle glopagus
davidhar's Avatar
Indeed. I just lubed my Jiffy thinking about it.
davidhar is offline   Reply With Quote
