fuel issue, cleaning injectors? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-20-2012, 10:52 PM   #1
cirsory
cirsory's Avatar
Motorcycle: 06 600 track
symptom: bike cranks a few time before starting then immediately dies.
So its goes crank crank crank crank VROOM dies....... whether i am continuously holding the starter or not.
I'll try to get a video tomorrow.
I think its not getting enough fuel. This is a salvage bike and has probably been sitting for 3-6 months in a junk yard. I already dumped the old fuel out and it came out clean, and the inside of the tank looks clean too. New fuel is in with some stabil.
Going to do two tests tomorrow. The how much fuel does the pump pump test and also spraying starter fluid into the cylinders to verify it is a fuel issue.
My question is..is there an easy way to clean the injectors with it on the bike? Maybe spray/pour injector cleaner into the fuel line then start it to get it in there then repeat a few times?
cirsory is offline   Reply With Quote
Old 11-21-2012, 08:21 AM   #2
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
Re: fuel issue, cleaning injectors?
I agree that you should try the starting fluid to confirm it is a fuel issue. It sure sounds like it.
I really don't think it is the injectors. I would look for a fuel restriction.
1. check the hoses from the fuel pump to the rail for kinks.
2. check the fuel filter for debris.
3. do a pressure test on the fuel pump (I'm guessing that is it is cycling and running)
The procedure is in the service manual.
rv6john is offline   Reply With Quote
Old 11-21-2012, 03:58 PM   #3
cirsory
cirsory's Avatar
thanks, thats the kind of answer I needed. I didn't think of doing a pressure test. I just so happen to have that tool at work too!
Hoses are ok. I don't think theres debris in the filter since the old fuel looked clean but I'm not sure on this, the pressure test will help me verify.
Old 11-21-2012, 04:09 PM   #4
HardRacing
Site Sponsor
HardRacing's Avatar
Motorcycle: 07 GSX-R1000, . OHLINS_MASTER_DEALER
If it's sat for a while, did you try to start it with old / bad fuel ? If so you've prolly killed the spark plugs. Would try new ones to rule them out before you started way deep into fuel pump / injector issues.
HardRacing is offline   Reply With Quote
Old 11-21-2012, 04:52 PM   #5
cirsory
cirsory's Avatar
I did try and start it before, and it was doing the same thing. I then dumped the fuel and pulled the spark plugs and cleaned them. They physically look fine though. The starting fluid will also help verify this.
Old 11-21-2012, 06:43 PM   #6
cirsory
cirsory's Avatar
well with starting fluid it displayed the same symptoms. I'll put in new spark plugs after the holiday weekend and try again.
Old 11-24-2012, 07:08 PM   #7
rv6john
So are you giving it just a squirt of starter fluid or spraying it in while cranking to try and keep it running? I'm not sure from your reply.
Old 11-25-2012, 11:03 PM   #8
cirsory
cirsory's Avatar
I squirted some in the intake and tried to start. It only cranked so then I sprayed some while cranking and wouldn't fire as it would normally.
Old 11-30-2012, 07:37 PM   #9
cirsory
cirsory's Avatar
Update:
Bought new spark plugs. Took out old ones, cranked a few times without plugs to clear any leftover gas/oil/flooding.
Installed new plugs. Same result. With starter fluid initially would fire then die immediately. Then it wouldn't even fire with starter fluid. It wants to but doesnt.
Verified good gas is flowing.....that was a mess.
Waiting for video to upload to show.
Old 11-30-2012, 07:39 PM   #10
cirsory
cirsory's Avatar
Should I be able to see the gas squirting out of the injectors when I crank it? I'm not seeing anything coming out at all.
Old 11-30-2012, 07:44 PM   #11
cirsory
cirsory's Avatar
http://smg.photobucket.com/albums/v2...130_192407.mp4
Old 11-30-2012, 08:02 PM   #12
cirsory
cirsory's Avatar
just checked for spark...no spark
wheres the electrical troubleshooting instructions....i hate electrical issues
Old 11-30-2012, 09:00 PM   #13
rv6john
Service manual at www.servicemanualsgsxr.com.
The wiring diagram is in the back.
Old 11-30-2012, 09:12 PM   #14
cirsory
cirsory's Avatar
thank you for the help rv6. I think I have found the problem. I did a regulator test. I get nothing when connecting either w1/w2 to b1 or b2. w1/w2 to b3 gives a good reading including all the other diode tests on it.
i tested this first because there some physical damage(edge fins broke) to it from a wreck.
Old 12-01-2012, 08:44 AM   #15
rv6john
I don't mean to burst your bubble, but you could totally disconnect the R/R and the bike will start and run as long as the battery holds up.
It does seem that you will have a charging problem once you get the bike running.
Old 12-01-2012, 02:45 PM   #16
cirsory
cirsory's Avatar
I KNOW this and had a brain fart. I was tired and frustrated. the worst time to work on a bike haha
I received an instrument cluster today and wired that up. I turned on dealer mode to check the codes and 3 codes came up. Two codes I expected but not the third. It was the TO sensor code.
Looked for it and finally realized it was missing. The cables were broken off inside the cable housing so I didn't realize anything important was missing.
Followed some instructions to bypass it using resistors and it fired up and ran.
Old 12-01-2012, 04:54 PM   #17
2007gsxr600
2007gsxr600's Avatar
Motorcycle: L1 750
good thing i went thru all the posts was def going to say to check the TO sensor since it was in a crash.... glad you figured out the problem...
2007gsxr600 is offline   Reply With Quote
Old 12-01-2012, 07:25 PM   #18
rv6john
Excellent.
