Weird headlight question : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 11-20-2012, 03:58 PM   #1
dan uk
Motorcycle: i hate bikes
My K2 750 headlights UK Spec are 2 H7's. That being single filament dipped on the left and raised main beam on the right.
I WANT H4's !!!
But, ignoring the wiring change which is easy with a relay and a bit of soldering. The question is the headlight unit itself.
Is the H7 headlight different to the H4 one other bthan the bulb that slots into it.. I mean the right-hand-side main beam i could adjust to be the same as the left (as it's pointed higher for the main beam) so that's easy. But when switching on the H4's from dipped to high beam would it actually raise the beam just by switching filaments ???
Confused.
Thanks in advance
Long time gixxer.com member
dan uk is online now   Reply With Quote
Old 11-24-2012, 12:40 PM   #2
dan uk
Re: Weird headlight question
bump... come on guys i know it's winter...
Old 12-11-2012, 02:54 PM   #3
dan uk
Ok to keep it simple..
Can i use H4's in a light unit that takes H7's ??? Are the light units the same ?? Other than the mounting/resepticle change, will it impact of light performance/efficiency.
Old 12-11-2012, 03:16 PM   #4
Spook155
Dick/Vagina Embracer
Spook155's Avatar
Motorcycle: '03 Suzuki GSX-R600, '03 Alstare GSX-R600Z
Lights are lights, just adjust them properly, find a way to mount them and manipulate your wiring to accommodate.
Spook155 is offline   Reply With Quote
Old 12-11-2012, 05:08 PM   #5
dan uk
Thanks mate
So there's no sensible reason why i shouldn't just get the H4 HID's and the relays to convert mine to US spec instead of the single sided H7 setup
