how to take apart water pump : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-19-2012, 01:27 AM   #1
pineconecow
pineconecow's Avatar
Few days ago at the dyno getting a custom tune and half way through oil starts spitting out under the water pump pretty good.. I took it off and decided it was most likely the internals of the water pump. #4/5. questions is, could someone describe the tools needed and the process to disassemble this internal part to replace the internals? I have no idea.
pineconecow is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 09:43 AM   #2
2007gsxr600
2007gsxr600's Avatar
Motorcycle: L1 750
Re: how to take apart water pump
i never heard of anyone try to rebuild a water pump.
thats usually a part you just replace when it craps out on you.
but if you or someone on here has or knows somebody that has "rebuilt" a water pump post up...
2007gsxr600 is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 10:02 AM   #3
Zippysport
Same here. You can probably even find a cheap used one on eBay if you want to. I replaced mine on my 2002 bike after cracking the driving shaft due to freezing water in the system.
Zippysport is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 10:04 AM   #4
TheGeek
Stupid. Who's with me?
TheGeek's Avatar
Motorcycle: Anniversary Edition 600 & Million Edition 1000
What part do you think failed exactly to cause it to leak?
TheGeek is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 10:43 AM   #5
MAD_ARAB
MAD_ARAB's Avatar
Motorcycle: A revamped K6 liter
There are two seals Internally. One for the water and the other for the oil. The weep hole is in between both of them so the leak will tell you which seal is bad.
MAD_ARAB is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 11:48 AM   #6
pineconecow
I couldnt turn the engine on, if I did the oil would be drained in 5 seconds from the bike. it was shooting out, a solid constant stream. then after off continued to drip. When taking of the coolant hoses it looked clean. The bike is an 06 and has 4000 miles. it was in storage for at least 4+ years id imagine. when I bought it 6 months ago it only had 2000 miles.
They sell the parts, but I have no idea how to get inside that piece. Looks like i might be buying a new pump.
Old 11-19-2012, 12:06 PM   #7
TheGeek
TheGeek's Avatar
I know that, just wondered why the OP thought it was there and not a cracked housing, blown seal in the shell, etc. Basically, was it even diagnosed. All too often people take shit apart that doesn't need to be.
Service manual has the procedures. It's not too difficult.
Old 11-19-2012, 01:36 PM   #8
pineconecow
right, taking I apart wasnt bad, but #5 is still stuck inside the whole piece. Somehow it needs to come out.
Id have to say something was blown out due to the large volume of oil spewing from the hole.
In the end I believe it was too much oil in the case causing too much pressure
Old 11-19-2012, 01:43 PM   #9
TheGeek
TheGeek's Avatar
too much oil should puke up the breather tube and into the airbox, not blow out seals.
As for how to do it.... factory service manual, section 7, page 11.
Old 11-19-2012, 10:01 PM   #10
2007gsxr600
Motorcycle: L1 750
maybe the op should also check the air box at that point. but even thru the weep hole it
couldn't just spit out oil that fast. im lost.... OP if you could post up pics of the bike
and how the oil was coming out and what not might make it easier for the rest of us
trying to help to get a better understanding of how the oil was pissing out like you
said...
Old 11-19-2012, 11:40 PM   #11
pineconecow
said...
right, To clarify, the bike was overfilled with oil and I knew that and thought not much of it. thinking excess oil would simply be vented out. I didnt think it was a sealed system, but the guy running the dyno seemed to think so. It has been sitting for a very long time and bouncing up to rev limiter multiple times is what I believe caused the pump to go. what I have never done.
Started with a few drips off the bottom screw of the pump, then a solid stream from what I saw directly above that bottom screw, but behind the pump. Only makes sense it was the weep hole.
Now if only I could remove #5 and replace #4/5/8/9. I would be set.
trying to go the cheapest route here and avoid buying one time bearing puller tools..
I appreciate all of the help so far.
Old 11-20-2012, 12:58 AM   #12
2007gsxr600
Motorcycle: L1 750
found a new water pump assy kit over at ronayers.com for a reasonable price 185
http://www.ronayers.com/fiche/TypeID...up/WATER_PUMP_
cheapest ive found yet.... looks to come with everything needed too....
would def be the way i would go about it IMO only because something goes wrong or
breaks as you're trying to go about rebuilding it and youll end up spending more money
and time than you need to...
Old 11-20-2012, 06:37 PM   #13
pineconecow
would it happen to be true that 08/09 water pumps would fit the 06/07?
and would this all come assembled if I purchased from a site?
Old 11-20-2012, 06:55 PM   #14
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
06 and 07 are one series p/n 17400-01H00
08 and 09 are a newer series p/n 17400-01H10
Different p/n but don't know the difference.
Yes, they come all assembled.
rv6john is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 01:07 AM   #15
ghowstryder
same part, just different color (black). It is what I have on my 07 right now.
ghowstryder is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 09:02 AM   #16
rv6john
Good info
Real Name
What is your real name?
Search this Thread:
Advanced Search
