» Site Navigation
» Motorcycle Forums
11-16-2012, 03:14 AM
#1
best gsxr 1100w carter protection
Hello all,
I crashed my previous engine when i ran into an pedestrian. Now i don't want this to happen again (the carter beeing broke that is
). What is the best way to protect the carter?
Carter slider?
Crash pads?
Thanks.
11-17-2012, 09:41 AM
#2
Carb Ninja
Motorcycle: 96 GSXR750, 07 CBR1000RR
Re: best gsxr 1100w carter protection
WTF is a "carter", and why do you need to protect it?
11-17-2012, 09:46 AM
#3
Originally Posted by
ccmhunt
Between Ford & Reagan?
11-17-2012, 09:57 AM
#4
Carb Ninja
Doesn't he have secret service protection already? Maybe we should report this guy to homeland security?
11-17-2012, 10:17 AM
#5
ccmhunt
I've attached the part that i'm referring about. This particulair point is very weak with the gsxr. Normally you would have your fairings but in case of an streetfighter it fails first. Oil was pouring out like mad.
I obviously want to protect it from happening again i case of sliding my bike somehow.
11-17-2012, 11:50 AM
#6
Motorcycle: GSXR750/1100W racer and GSXR750SP
I did this.
First made a aluminium plate and then attached a nylon block with velcro on it.
11-19-2012, 09:48 AM
#7
Motorcycle: 93 GSXR 750
BenjaminDG
NIce Ben...I think I've just found a little winter project for myself!
11-19-2012, 10:54 AM
#8
Definitely one of the weak points of the engine.
That parts actually sticks more out the the cyllinder head and the only thing that protects from the pavement is 3mm thick abs plastic.
I took the idea from TJS's gsx-r which futures a similar protection.
11-19-2012, 01:01 PM
#9
Sent Flowers to Algernon
Motorcycle: THE SRADIATOR
They should have incorporated a replaceable puck into that design but that would have cost an extra 50 cents at the production end which would have translated in 500.00 at the retail end.
11-19-2012, 01:14 PM
#10
Carb Ninja
I still want to know what carter has to do with this?
11-19-2012, 01:26 PM
#11
I'm not going to ask him:
11-20-2012, 06:57 AM
#12
Carter is dutch for (engine)casing.
Not the president i think
11-20-2012, 06:59 AM
#13
Sabba
The bottom bolt that hold the aluminium casing protection is special threaded.
The same thread they used for the older mirrors on bikes.
I tought M10x1 or M10x1.25 but i'm not sure anymore.
11-20-2012, 10:26 PM
#14
BenjaminDG
Good to know, thanks.
What is that bolt for originally, do you know?
11-21-2012, 07:37 AM
#15
That bolt is acutally a plug for the oil channel that feeds oil to your crankshaft.
So make sure that bolt isnt to long or you will block off the oil lubrication for the left side of the crankshaft.
11-21-2012, 09:00 AM
#16
BenjaminDG
I did this.
Very nice Ben. Sorry about the 'carter', yes it's the housing idd.
11-21-2012, 07:29 PM
#17
BenjaminDG
As I suspected...
11-22-2012, 03:50 AM
#18
Sabba
I was thinking about this last night but you could aswell just put some sliders in the lower bolt couldn't you?
11-22-2012, 09:44 AM
#19
I think the pressure on the slider would crack the engine casing...
Ben's method is much safer...
Linear Mode
