Electrical question re: relays : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Mods & How To's
Old 11-15-2012, 08:06 PM   #1
Claymation
Claymation's Avatar
Motorcycle: '11 GSXR-750
So I recently purchased a Stebel Nautilus compact airhorn. I had to separate the compressor from the horn, got everything mounted fine. The compressor had two electrical tabs that worked perfectly with the OEM connectors that the stock horn used. I hooked it up and its very loud and seems to be working great but here's my question. The wiring instructions say to wire it using a relay (provided w the horn). I don't understand relays, obviously. Will the horn get more power (and be louder) if i use the relay?
Claymation is offline   Reply With Quote
Old 11-15-2012, 11:24 PM   #2
Newbmitch
Newbmitch's Avatar
Motorcycle: 2007 GSXR750
Re: Electrical question re: relays
if your not blowing fuses then i cant see any point in a relay. Relays in this configuration are just a heavy capacity switch that is activated by the main horn button. The benefit of this would be to not destroy the factory switch if the unit your installing takes more current than the old horn. But they suggest to do it anyways so why not try hooking it up. good learning experience. relays seem complicated but they are really simple. manufacturer had good instructions on their site
Newbmitch is offline   Reply With Quote
Old 11-16-2012, 08:20 AM   #3
Claymation
Claymation's Avatar
Thanks buddy. Makes more sense. I'll try installing it this weekend.
Old 11-16-2012, 09:16 AM   #4
600k2
It's a Jersey thing
600k2's Avatar
Motorcycle: 600k2
A relay is used so a light duty switch can activate a heavy duty circuit. Your horn button is a light duty button and the new horns draw some big power. You might want a relay.
Blowing fuses and using a relay have nothing to do with each other. You need to have a fused power source to the relay. A relay does not make the circuit draw any less amps. A relay is used so a light duty switch can activate a heavy duty circuit.
A relay is used to split a circuit into two parts.
Part 1 is the control side of relay. Terminals 85 and 86 have an electromagnet coil between them. When the coil is energized (meaning power and ground are supplied to the terminals) the relay connects terminals 30 and 87 together turning the relay "on". The power draw across terminals 85 and 86 is measured in milliamps. This allows any type of switch or the use of an ECU to activate the circuit without having to worry of it burning out.
Part 2 is the load side of the relay. Depending on your relay, there are either 4 or 5 terminals on it. They are labeled 85, 86, 30, 87, (and 87a if 5 terminals) If you have an SPST (single pole single throw) relay then you have 4 terminals; 85, 86, 30 and 87. If you have a SPDT (single pole dual throw) relay then you have 5 terminals; 85, 86, 30, 87 and 87a.
85 and 86 are used for turning the relay on and off. 30, 87, and 87a do the work and handle the amps. This is the heavy duty switch part. 30 and 87a are connected together when the relay is off. When the relay is turned on, 30 and 87a break connection, but 30 connects to 87. Turn the relay off again and 30 and 87 disconnect; 30 reconnects with 87a.
If there is no 87a terminal then it is just a single connection between 30 and 87 being made and broken.
You can use your factory horn button for your new horns, but you might burn the button out since it is not made to handle the power draw of the new horns. Using a relay, you can use the factory switch to activate the relay, which handles the power for the new horn.
CCS AM #317
WERA novice #317
President of the Anti-Driven D3 Grips Coalition
Originally Posted by njracer View Post
I'm old and I don't really know what I'm doing most of the time
1:50
600k2 is online now   Reply With Quote
Old 11-16-2012, 09:23 AM   #5
600k2
It's a Jersey thing
600k2's Avatar
Motorcycle: 600k2
If you want a picture it might make it easier.
