Re: BAUCE RACING BLACK FRIDAY-CYBER MONDAY Fren Tubo brake lines group buy
These are the most flexible, easily routable lines out there.
All kits include all protective materials needed as well as provisions for perfect fits.
They are also some of the lightest lines out there with a titanium hardware and fitting option pricing em into WSBK territory. :laugh
The type 1's are super duper affordable, and the kevlar kits (type 3) are not expensive and have a huge range of colors and fittings like the type 2's do!
There are 4 different types (type 1, 2, 3, or 4)
See what each type offers.
All kits are COMPLETE! Flex tube to cover spots, stock routing, etc.
Special requests for extra length is NO problem.
Type 1 kit-
Weigh around 1lb (16 oz.) -
The type 1 lines are stainless steel braided lines with steel hardware
Natural colored stainless steel fittings, banjo bolts, and hardware
These kits are extremely affordable!
The lines are available in this following colors!
Orange (KTM), Green, Yellow, Red, Blue, White, Black, Clear, or Smoke
Type 2 kit-
Weighs around 13 oz.
The type 2 Kits are the same stainless steel lines as the type 1 kits
The Type 2 kits come with aluminum hardware.
The benefits are reduced weight
And you can choose colors to coordinate with your line color
Aluminum fittings can be had in black, red, or blue
Line color options: Orange (KTM), Green, Yellow, Red, Blue, White, Black, Clear, or Smoke
Type 3 kit-
Weighs around 8 oz.
The type 3 Kits use lines made of Kevlar
They are much stronger lines and have a higher burst rating than a stainless line would
The Type 3 kits come with aluminum hardware.
These are the lightest lines Fren Tubo offers!
Aluminum fittings can be ordered in black, red, or blue
Line color options: Orange (KTM), Green, Yellow, Red, Blue, White, or Black.
Type 4 kit/Carbotechs-
Weighs around 9 oz .
The type 4 Kits use lines wrapped in carbon fiber
These lines are unbelievably flexible
They have the one of, if not the highest burt rating of any available to the public
The Type 4 kits come with black or silver aluminum hardware.
The lines come in carbon color and a clear protective tubing can be added on from the factory like I have for extra piece of mind!
These are one of the the lightest lines Fren Tubo offers!
These lines can be upgraded to a type 5 which has titanium hardware and is wsbk priced type stuff in case you’re a high roller. :
