Floating rpm.. I've searched : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-13-2012, 07:47 PM   #1
IdkWhatImDoing600
Okay so be I've never worked on a bike in any major way befor and i have just got a 97 600.. The problems I'm having are that the bike will fire no problem.. It will have a very hard time idling (but won't die) and after a few min or less of idle it will jump rpm up to about 6000 and stay there.. Some times it will drop back down but only sometimes.. And when idling if I rev it just the smallest bit it will jump rpm and stay there.. I also get popping when it's at 6000(think cuz it's lean) like my username says i do not know jack about bikes so any help would be great..
P.s I think it night be my tps??
IdkWhatImDoing600 is offline   Reply With Quote
Old 11-13-2012, 08:37 PM   #2
ccmhunt
Carb Ninja
ccmhunt's Avatar
Motorcycle: 96 GSXR750, 07 CBR1KRR, ZX7/9RR F-USA AMA
Re: Floating rpm.. I've searched
I doubt that it's a tps, they have almost no effect on a carbed bike, you can disconnect it at idle, and nothing changes.
Initially, not knowing anything else about your bike, I would look for vacuum leaks.
It's a 97 600,so I am assuming that unless someone has swapped model years, your carbs do not have solenoids, so that simplifies things.
I heck and make sure the manifolds are tight, that the carbs are seated fully into the manifolds, that the small line on the petcock is connected to the intake #3 under the carbs, that the airbox is sealed well.
Spray carb cleaned around everything while it is running and listen for fluctuations.
Originally Posted by ccmhunt View Post
hmmmm
Originally Posted by Apok View Post
^ He's come to finish the job from the Driven Gas cap thread!
Originally Posted by Armi View Post
Terry, has he gone yet?!
Pretty sure, I distracted him with a text message.We should be safe for now.
ccmhunt is online now   Reply With Quote
