Calliper swap : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 11-13-2012, 01:35 PM   #1
U.K K4 600 MR ED
U.K K4 600 MR ED's Avatar
Calliper swap
Hey everyone, a question about the callipers on my k4 600 ,they work fine it's just that I prefer the black ones on the later models.i know the k4 has 300 mm discs but the k5 onwards has 310 mm discs,would this affect fitting or would I have to put spacers in( I'm guessing 10 mm?),or can I just put them on,they look the same just in black,cheers.
U.K K4 600 MR ED is offline   Reply With Quote
Old 11-13-2012, 02:07 PM   #2
Travis V
I dont love OG's cack anymore
Travis V's Avatar
Motorcycle: 2005 GSX-R 600 - Future Track Bike
Re: Calliper swap
Need a spacer
Travis V is online now   Reply With Quote
Old 11-13-2012, 03:30 PM   #3
U.K K4 600 MR ED
Re: Calliper swap
How big of a spacer?
Old 11-13-2012, 04:36 PM   #4
Nafterclifen
Motorcycle: 04 GSX-R 600
Re: Calliper swap
If you were to install larger rotors on your wheel and use the factory calipers, you would need to use spacers.
If you want to install calipers from another bike that were meant to fit a rotor larger than 300mm, which is what's on your bike, you will need to have the mounting posts of the new calipers milled down to fit. The exact amount of material that needs to be removed depends on the size of the rotors from the other bike.
Nafterclifen is offline   Reply With Quote
Old 11-14-2012, 04:01 AM   #5
U.K K4 600 MR ED
Re: Calliper swap
Thank you.
Old 11-21-2012, 09:09 AM   #6
meat_whistle
meat_whistle's Avatar
Motorcycle: '04 gsx-r 600
Just pick up rotors from the same model year which you pick up calipers from. that would save you a lot of headaches I'd imagine.
Sent from my iPhone using Motorcycle.com Free App
meat_whistle is offline   Reply With Quote
