how does the seat latch bolt on : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-12-2012, 09:50 PM   #1
86boiler
i cant figure it out. trying to bolt the seat latch to either one of the cross members. i believe theres 4 screws that hold it down with nuts on the opposing side but the bolt holes just dont line up. forgive my ignorance as i have an 85 and i am converting it to an 86. this is the front latch, the gold one with the double tit acceptor. lmfao
86boiler is offline   Reply With Quote
Old 11-13-2012, 05:05 PM   #2
remusr
remusr's Avatar
Motorcycle: GSXR1K5's street & track, GSXR1100G
Re: how does the seat latch bolt on
Yup - just checked my 8611 - large gold metal assembly with edge 2 pin-holes & 1 central spring-loaded pin (not 2) on front crossmember, cable mounted to front left, mounted with 4 screws in the wider-separated crossmember holes with flanged nuts on bottom. Smaller black plastic assembly with 1 pin-hole mounted with diagonal 2 screws/nuts in narrower holes on rear crossmember, cable to left side. Never seen the 85 but the swap guide says 86 latches are supposed to bolt on the 85 frame if you move the big one to the front and put the small on at the rear.
http://www.cheapcycleparts.com/model...0-seat-model-g
remusr is offline   Reply With Quote
Old 11-13-2012, 05:51 PM   #3
86boiler
see heres the funny thing, both of my cross members have the same bolt spacing. making it not possible to bolt the gold one on. both cross members have the same bolt spacing used in the lock latch, the spring loaded gold latch has a different spacing making it not possible... weird? i read the interchange and im confused to heck now
Old 11-14-2012, 11:11 AM   #4
remusr
remusr's Avatar
My crossmembers look identical too, can put either assembly on either crossmember. I thought the 85 had the big assembly on the rear crossmember? If so, and you say both crossmembers are identical it must fit on the front one.
Old 12-04-2012, 02:26 PM   #5
86boiler
my 85 frame doesnt have the bolt holes that the arrows point to in the picture.
thus the interchange is wrong
Old 01-01-2013, 04:45 PM   #6
86boiler
anyone ?
Old 01-01-2013, 05:35 PM   #7
alexfleury
uhh drill new holes ? but I'll modify anything so don't pay too much attention to me lol
alexfleury is offline   Reply With Quote
Old 01-01-2013, 06:09 PM   #8
gotgixers
Superbike Racer
gotgixers's Avatar
Motorcycle: 1986 GSXR 7/12
Sorry, my 85 frame had holes there, thus the entry in the interchange. I guess someone could have drilled them over the years ....but they appeared OEM to me ......
gotgixers is offline   Reply With Quote
Old 01-01-2013, 06:44 PM   #9
86boiler
thing about that is that there is larger dime sized holes just out of line with the bolt holes that hold the little latch on. Therfore i dont have the "meat" to be able to sufficiently start banging new holes into the x member. Ill see if i can get some pics of what I have
Old 01-01-2013, 09:37 PM   #10
Tchatterton24
Tchatterton24's Avatar
Motorcycle: 1986 GSXR 750, 2012 Aprilia RSV4R factory, 2013 Aprilia SR50 Max Biaggi Replica
Remember the '85 had a two piece seat and the '86 had a one piece. Maybe that's the difference
One of the '85 owners will chime in shortly and shed the light for all of us
Tchatterton24 is offline   Reply With Quote
Old 01-01-2013, 11:45 PM   #11
alexfleury
My 750 frame that had a one piece seat had the four holes in both posts. So does the 1100 frame that I have. Sorry not sure about years.
Old 01-02-2013, 12:25 AM   #12
86boiler
whipped up a rough sketch of my 85 front member
Old 01-02-2013, 02:52 AM   #13
gotgixers
Superbike Racer
gotgixers's Avatar
I am aware of this. I usually run an '85 2pc seat on my 86 frame. As they are more comfy ....
And I have put an '86-'87 1pc on an '85 frame also ....
Here is a pic of the '85 seat I run on my '86, cant find the pics of the '85 right now, on my other HDD ....
File Type: jpg 2407_1090539350564_1438898996_254308_814334_n.jpg (57.5 KB, 42 views)
Old 01-02-2013, 10:07 AM   #14
nealhan
nealhan's Avatar
Motorcycle: 1992 GSX-R 1100
+1.. Never knew it was that serious...
nealhan is offline   Reply With Quote
Old 01-02-2013, 01:05 PM   #15
86boiler
i really wouldnt care if there was only the one seat latch but do i have to worry about my seat coming off?
Old 01-03-2013, 12:51 AM   #16
ozboy
ozboy's Avatar
Motorcycle: GSXR750,1100
This may help; on the '85, there is only 1 seat latch, the rear seat is screwed on.
Regards, Oz
ozboy is offline   Reply With Quote
Old 01-03-2013, 02:45 PM   #17
javadog
Yoshimura junkie
javadog's Avatar
Motorcycle: 1986 GSX-R750R, 1986 GSX-R1100, 1989 GSX-R750RR, 1997 GSX-R750, 2001 GSX-R1000, 2001 Bandit 1200S, plus a few others.
SO, you've now figured out that an '85 used the smaller latch in the front, as did the 86 Limited.
Two options:
Find a way to mount the correct latch assembly on the front.
Modify the seat to accept the post for the smaller latch at both points and install those latches in both places on the subframe.
JR
javadog is online now   Reply With Quote
