Stator or battery going bad... : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-12-2012, 06:10 PM   #1
Swank
Motorcycle: 2007 GSX-R 600
I have a 2007 600 that I bought last year. When I bought it the guy replaced the battery. I ride it everyday, well almost everyday. Normally my trips are 2-4 miles at a time. The weather here has been getting colder. Dropping down to low 30s. The bike has been getting harder to start, as in needing to crank more before firing. Today, after riding the bike about 4 miles or so, I parked my bike at this business I was going to and turned it off. After I found out I couldn't park there I tried to start the bike and it cranked for a few and then eventually wouldn't crank at all. The lights were still on but it wouldn't crank. I think the clock reset too. Anyways I left the bike there and them came back about 4 hours later and tried to start it again. This time after a few extra seconds of cranking it started up. I have it on a trickle charger for the night. Do you think its the stator or the battery? I'm not really sure how to tell which one it might be. Thanks.
Swank is offline   Reply With Quote
Old 11-12-2012, 06:37 PM   #2
Samantha750
Scandinavian Mod with PMS
Samantha750's Avatar
Motorcycle: Two wheels and goes VROOM, VROOM
Re: Stator or battery going bad...
The K6/7 are notorious for having rectifier issues, so chances are it's neither the stator or the battery. Either do a search and/or download a service manual and test the voltage at the battery with bike running at 5,000 RPM's. Voltage should be between 14-15.5V.
Samantha750 is online now   Reply With Quote
Old 11-12-2012, 07:19 PM   #3
Ironhead401
Came out of retirement to "catch" for a bunch of 20-24 year old men!
Ironhead401's Avatar
Motorcycle: 2004 GSXR 600
Follow this flow chart to diagnose. http://racetechelectric.com/files/pd...flow_chart.pdf
Ironhead401 is online now   Reply With Quote
Old 11-12-2012, 11:31 PM   #4
Zlow28
16.8@186.1
Zlow28's Avatar
Motorcycle: 2006 GSXR 600
Pretty weird, i just posted a thread similar to this. Id do as samantha suggested, and check the rectifier and stator first. The stator is what keeps the bike running once its on.
If someone chimes in on my thread ill let you know and hopefully itll help you out too.
Zlow28 is offline   Reply With Quote
Old 11-29-2012, 01:57 PM   #5
Swank
Did you get any other information on this? I have to let my bike sit for atleast an hour before starting it up. If I start it any sooner it will sound like its dying but if I let it sit for an hour it will fire right up. Which by the way is super annoying considering I haven't fixed it yet and had to walk home today.
Old 11-29-2012, 07:37 PM   #6
Zlow28
16.8@186.1
Zlow28's Avatar
I raised my cold start idle, and it kinda worked. I still have to give it around 5% throttle to start her up, after that no problem.
Bump up your cold start idle to around 1900rpm and leave your warm idle to 1300 ±100.
Did you check your stator and rectifier?
Old 11-29-2012, 08:00 PM   #7
Swank
I'm doing that right now. I did the flow chart on it but I ran a trickle charge on it the night before. I'm thinking that might've given me a false positive. I'm trying to figure out how to get to the stator and rectifier to check the connections. When I did the flow chart the first time that is where it led me too. We will see how it goes. I'm thinking I might need to pull a lot apart to get to them. Also when I start it right after running it sounds like there is very little "juice" in the battery. So I have to let it sit for a while. I'm not sure how to adjust the idle.
Old 11-29-2012, 08:47 PM   #8
Swank
Is the RR the same thing as the rectifier? or is that a different part?
Old 11-29-2012, 08:57 PM   #9
Zlow28
16.8@186.1
Zlow28's Avatar
Its all gonna be in the manual.
The rectifier is probably the easiest one. Id take care of that one first just to get it out the way. Unbolt it and lift the gas tank to remove the airbox. Its held down by a bunch of screws on the edge of the black airbox IIRC. Itll give you access to the wires that lead off from the rectifier. Then use a multimeter to test out the connections mentioned in the service manual.
The stator will work the same way, except youre gonna need to test it with a different setting of course, and with the bike turned on. You need both readings at idle and at around 4 or 5k rpm.
Keep us posted.
Old 11-29-2012, 08:58 PM   #10
Zlow28
16.8@186.1
Zlow28's Avatar
yeah RR is the rectifier
Old 11-29-2012, 09:38 PM   #11
Swank
I took of the top of the screws to the airbox but I'm not able to get the whole unit off without loosing the screws of the 4 air intake valves. Is there an easier way to get to it? Should I take off the radiator? That's my next bet it is to try to take that off. I'm can sort of see the wires but I can't get to them.
Old 11-29-2012, 09:43 PM   #12
Zlow28
16.8@186.1
Zlow28's Avatar
Go ahead and remove the screws from the intake valves. I forgot to mention those. Just make sure you keep them very well covered as you dont want anything to get in there. I used blue painters tape to cover them up when i did this.
Old 11-29-2012, 10:15 PM   #13
Swank
Can't get to the screws. They are a HUGE pain. I'm trying to remove the gas tank but I have no idea on if I remove some of the hoses if fuel will spill out. Do you know anything about that?
Old 11-29-2012, 10:23 PM   #14
Zlow28
16.8@186.1
Zlow28's Avatar
You dont have to remove the gas tank. Just lift it.
As for the screws, they really are a PITA. Check this thread out for tips
http://www.gixxer.com/forums/showthread.php?t=279031
Old 11-29-2012, 10:23 PM   #15
Swank
Also having a really hard time trying to loosen in the 2 inside screws for the in take valves. Is there a specialty tool that is needed for those? Do you think they could make the bike any harder to work on?
Old 11-29-2012, 10:32 PM   #16
Swank
Got it off finally! it was a pain but I used a regular screw driver and just angled it with some pressure at the middle 2 and them came out. Thanks for the help. I'll let you know how it goes with cleaning the connections and trying it out.
Old 11-29-2012, 10:36 PM   #17
Ril3y
Ril3y's Avatar
Motorcycle: 2007 GSXR 600
Also to double check to make sure its not also the battery, charge it and test it as well under load, not just checking the surface charge..
Ril3y is offline   Reply With Quote
Old 11-29-2012, 10:45 PM   #18
Swank
Well the battery is only a year old and I have put the trickle charge on it. When I did that and did the test I get the same result as I did today when it wasn't on the trickle charge. So I assume that it isn't the battery. I just sprayed contact cleaner on the connections for the stator and regulator. So hopefully that is the problem. The voltage meeter I have is saying that I'm at 14.7 volts so it points to cleaning the connections. We will see.
Old 11-30-2012, 01:13 AM   #19
Swank
Well I cleaned the connections. Took it for a 5 mile ride or so came home. I let it sit for 5 minutes and it wouldn't start. It did the battery isn't charged thing. I followed this test,
, and the outline I have, from earlier in the post, and I don't know where I went wrong. They stator checked out fine. Atleast from what the youtube video said. The rectifier is the one that keeps it running I thought? So maybe I should buy a new stator? I'm not sure where to go from here. Anyone else have any ideas on it?
Old 11-30-2012, 01:38 AM   #20
Samantha750
The stator is the alternator that generates electricity, the rectifier converts from AC to DC and regulates the current. If the rectifier goes out one of two things happens, it does not charge the battery or worse, it cooks the battery, blows fuses and can damage the ECU. K6/7 have known rectifier issues and fried rectifiers are common as I previously stated. Maybe take it to a shop, you say the stator tested fine but you want to buy a new one?
