How a choke in a carburettor works....explanation! : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-12-2012, 04:08 AM   #1
Armi
Superbike Champ
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
Actually i'm looking for one?
After that thread...cam't find it, I owed an explanation, as to how it works.
Have done some reading and am abit confused.
Read in one tuturiol that when it's cold, fuel sticks to the cylinder walls and therefore requires MORE fuel to start the bike....didn't say how it provides the extra fuel?!?!?!
In another tutorial, it says that the choke opens an air circuit and runs the engine at a higher rpm, which is totally contradictary to what was said above?
Whats a throttle valve?....that's the slide, right?
K6 thou forks/"K Tec" Springs, Brembo 19x20 RCS m/c, R1 calipers, Hel ss lines, Renthal dual compound grips, DID x ring gold chain, Renthal -1+2 sprockets, Sudco full exhaust, BMC filter, Gilles rearsets, Factory Pro engine covers, Samco Hoses, Ohlins rear shock, GPR steering damper, Yoshi MJN Jet kit thanks to our resident carb Ninja CCMHUNT!
Armi is offline   Reply With Quote
Old 11-12-2012, 06:13 AM   #2
dj_smurph
Motorcycle: 98 600 srad,97 aprilia chesterfield rs125
Re: How a choke in a carburettor works....explanation!
Throttle valve is the butterfly. The slide metres the fuel. The choke I think moves a butterfly that changes the air pressure difference across the carb and enrichens the air/fuel mix. How it does it I don't know
dj_smurph is offline   Reply With Quote
Old 11-12-2012, 07:13 AM   #3
TheGeek
Stupid. Who's with me?
TheGeek's Avatar
Motorcycle: Anniversary Edition 600
Throttle plate is below the jets. It doesn't change any pressures, only air velociy at the jet which is the venturi effect vacuum. The choke is above the jet. Closing it applies a direct vacuum at the jet increasing the fuel.
This is in the simplest terms. It can get much more complicated.
TheGeek is offline   Reply With Quote
Old 11-12-2012, 07:40 AM   #4
ccmhunt
Carb Ninja
ccmhunt's Avatar
Motorcycle: 96 GSXR750, 07 CBR1KRR, ZX7/9RR F-USA AMA
In your Mikuni CV'S this>> In another tutorial, it says that the choke opens an air circuit and runs the engine at a higher rpm,
Remember, I told you that the choke plunger opened an air passage from above the piston diaphragm to the upper venturi on the engine side of the butterfly . This was the direct effect.
Now, what is the indirect effect?
ccmhunt is online now   Reply With Quote
Old 11-12-2012, 08:33 AM   #5
dj_smurph
The idirect effect is it lifts the slide more increasing the amount of fuel while keeping the amount of air the same enrichening the mix
Old 11-12-2012, 08:37 AM   #6
THE SRADIATOR
Sent Flowers to Algernon
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
I know this one...Less air ='s More fuel?
THE SRADIATOR is offline   Reply With Quote
Old 11-12-2012, 08:40 AM   #7
THE SRADIATOR
Any time someone whips out the word "Venturi" you know it's going to get complicated!
Although...for some, the word "Floats" has complications and a life all their own!
Old 11-12-2012, 08:46 AM   #8
Armi
Superbike Champ
Armi's Avatar
I know what the venturi is.
If the choke plunger opens an passage above the piston diaphram, this will in turn lift the needle, allowing more fuel in,no?
I mean the slide, slides up the needle, allowing more fuel.
Can someone put up a correct diagram of whats going on?
Old 11-12-2012, 09:13 AM   #9
TheGeek
TheGeek's Avatar
Then that's not a choke... it's an enrichment mechanism.
Old 11-12-2012, 09:37 AM   #10
The real confusion comes in that choke enrichener and fast idle are all incorrectly used as if they are interchangeable only because they are used to achieve the same desired effect.
There are tons of things that are like this too.
Backfire/after fire
Flooding/gas fouling
Etc.
Moto_Joe is offline   Reply With Quote
Old 11-12-2012, 10:26 AM   #11
Iloveurmommy
Iloveurmommy's Avatar
This is probably one of the best guides IMO to understanding carbs. I know it helped me a great deal.
http://dl.dropbox.com/u/106752/Manua...etion_1975.pdf
Here is the thread I found it in:
http://www.thegsresources.com/_forum...ighlight=Great
Enjoy!!!
Sent from my iPhone using Motorcycle.com Free App
Iloveurmommy is offline   Reply With Quote
Old 11-12-2012, 12:16 PM   #12
TT750
Motorcycle: 99 750
cold fuel doesnt atomize well..
wish this showed a air choke like on the srad. instead the choke valve actually opens a port to let more fuel where in our carbs the choke valves lets vacuum travel to the diaphram and lift the slide and needle to let more fuel.
when you look at srad carbs and many others you will see the choke valve on the top of them. basically the direct opposite position then the video. because you want vacuum to be directed to the top side of the diaphram. when you pull the choke you open the port in the top of the bore on the engine side of the butterfly to let vacuum up to the top of the diaphram lifting the slide and needle.
99 750 srad.... my other hot blooded woman
Old 11-12-2012, 12:22 PM   #13
TT750
Motorcycle: 99 750
in this video you can see the fuel being atomized into tiny droplets as it comes out the main jet kinda cool
Old 11-12-2012, 12:58 PM   #14
ccmhunt
Carb Ninja
ccmhunt's Avatar
So after all the hints, we have a conclusion, the choke is an air mechanism, whose secondary function is to raise rpm and meter more fuel.
That's the distinction I was driving for, because all too often there is a misconception that there is a choke jet, or that the choke itself is metering fuel. So my questions in the other thread, that asked you all the ponder it, and gave you all the information that the mechanism opened the passage from venturi to chamber above diaphragm, was merely an exercise to make you arrive at a forgone conclusion and to remove the misconception of a choke fuel jet mechanism in our carbs.
Originally Posted by ccmhunt View Post
hmmmm
Originally Posted by Apok View Post
^ He's come to finish the job from the Driven Gas cap thread!
Originally Posted by Armi View Post
Terry, has he gone yet?!
Pretty sure, I distracted him with a text message.We should be safe for now.
Old 11-12-2012, 01:17 PM   #15
Apok
Motorcycle: '03 GSXR1000, '88 GSX 1100F, '92 GSX 1100F
You bastage, both of my answers pertained to that.
Apok is offline   Reply With Quote
Old 11-12-2012, 01:20 PM   #16
THE SRADIATOR
When he whips out the word "Venturi" from his vocabulary tool box, things are gonna get serious right quick round here! (I hate when things get serious as it goes against everything I stand for!)
Old 11-12-2012, 01:22 PM   #17
THE SRADIATOR
http://www.youtube.com/watch?v=wyspAHrMbb8
Ohhhhhhh...pretty colors!
See pretty...
Old 11-12-2012, 01:30 PM   #18
dj_smurph
https://www.youtube.com/watch?v=APq5...e_gdata_player
This shows mjn kit working as well as fuel atomising
Old 11-12-2012, 07:23 PM   #19
TwistedMister
TwistedMister's Avatar
In another tutorial, it says that the choke opens an air circuit and runs the engine at a higher rpm, which is totally contradictory to what was said above?
he said, it adds more air, he also said that in another thread a while back when I was going through my carbs when I thought fuel may be leaking out the choke o-rings..
he said "remember the choke adds more air"
I fear you blonds aren't going to do so well on the test...
TwistedMister is offline   Reply With Quote
Old 11-12-2012, 07:26 PM   #20
TwistedMister
This shows mjn kit working as well as fuel atomizing
is that the perforated needle set up?
like to get me a good set of spares and try those some day, prolly when I hit the lotto..
