HELP! Clutch Problem.
Working with a 2002 GSX-R 750
I am replacing the Clutch Friction plates. Drained oil, removed cover, removed 5 bolts/springs from the clutch assembly. I took the old plates out, went in with the new. rounded edge pointed inside. Got everything back together and the clutch lever has no pull back to it. Clutch does not engage or disengage. What do i need to check, what do i need to do? I have gone back into the basket and checked the plates 3x now. Help would be greatly appreciated.
