Tach/speedo Not working : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 11-06-2012, 08:45 PM   #1
warrior3535
Motorcycle: 2001 Yamaha R6 Championship Edition, 2005 Suzuki GSXR 600
Thumbs down Tach/speedo Not working
Anyone know what may cause the tach/speedo not to work? I have verified that it does work on a similar bike. But it is not functioning on my bike. Anyone else have this issue before?
warrior3535 is offline   Reply With Quote
Old 11-06-2012, 08:52 PM   #2
FlaGatorL
FlaGatorL's Avatar
Motorcycle: 2004 GSXR 750
The sensor
Sent from my iPhone using Motorcycle.com Free App
FlaGatorL is offline   Reply With Quote
Old 11-06-2012, 08:59 PM   #3
warrior3535
Re: Tach/speedo Not working
where is the sensor located? I'm just getting into this bike. Picked it up dirt cheap and working on putting it back to stock and making it ridable imo
Old 11-06-2012, 10:10 PM   #4
twnorton
Motorcycle: 05 GSXR 600
blown fuse
twnorton is offline   Reply With Quote
Old 11-06-2012, 10:13 PM   #5
warrior3535
Fuses looked good. little corroded but none of them looked blown. I'm planning on replacing all the fuses. Just haven't had the time yet with work
Old 11-07-2012, 05:17 AM   #6
Slaki
Slaki's Avatar
Motorcycle: 2007 GSXR 1000
Could be a few things.
What year model?
You can check the ECU pun, sensor, the speed plate attached to the sprocket, wire that runs to cluster... Give year model then we can check
Slaki is offline   Reply With Quote
Old 11-07-2012, 01:45 PM   #7
Ant_Farm
Motorcycle: '07 GSXR 600
http://www.gixxer.com/forums/showthread.php?t=342404
Maybe this will help...
Ant_Farm is offline   Reply With Quote
Old 11-07-2012, 01:48 PM   #8
TheGeek
Stupid. Who's with me?
TheGeek's Avatar
Motorcycle: Anniversary Edition 600
Large subharness connector under the left ram air tube.
TheGeek is offline   Reply With Quote
Old 11-07-2012, 10:22 PM   #9
warrior3535
Sorry Had the bike specs under my user name on the left but it is a 05 600 The large harness clip under the air ram tube has been replaced also looked a little cruddy
Old 11-08-2012, 07:37 PM   #10
warrior3535
Thannks for the help. Found a snapped off pin. Made a new pin for it and it works good now except my speedo. Which Might be my sensor. Or some of the corrided pins. Gonna get them cleaned up and then if that dont solve that issue try the sensor.
