Stalling at high speeds SRAD : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-06-2012, 04:34 PM   #1
ArodtheMan
Motorcycle: 2000 Suzuki GSXR 600
Angry Stalling at high speeds SRAD
I have a 2000 gsxr 600 with 21800 miles. This past sunday my bike died after I reached about 80 mph. The electronics did not cut off. It redline and died. Once I pulled over it started on choke and cut off around the same speed again. Could someone push me in the right direction. Carb has been cleaned
ArodtheMan is offline   Reply With Quote
Old 11-06-2012, 04:50 PM   #2
Armi
Superbike Champ
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
Re: Stalling at high speeds SRAD
Float heights...but i'm usually wrong!
Armi is offline   Reply With Quote
Old 11-06-2012, 05:04 PM   #3
ArodtheMan
In the carb?
Old 11-06-2012, 05:12 PM   #4
Armi
Superbike Champ
Armi's Avatar
Yes.
Old 11-06-2012, 05:17 PM   #5
ArodtheMan
I dont think thats the problem because after it happen I cleaned out the fuel filter and sprayed the carb cleaner in the carb and it ran great
Old 11-06-2012, 05:35 PM   #6
Fuel pump is going weak probably. Happened to mine.
There is a test procedure in teh manual. IIRC it should pump a smooth stream of fuel and fill a two liter in one minute? I forget the exact specs but it is in the manual. If it is a pulsing stream even if it gets close to the right amount I would replace the pump and it will likely fix it.
Moto_Joe is offline   Reply With Quote
Old 11-06-2012, 05:42 PM   #7
dj_smurph
Motorcycle: 98 600 srad,97 aprilia chesterfield rs125
Y tube from carbs to air box?
dj_smurph is offline   Reply With Quote
Old 11-06-2012, 05:54 PM   #8
TT750
Motorcycle: 99 750
side stand switch maybe..
Old 11-06-2012, 06:40 PM   #9
ArodtheMan
If its the fuel pump wouldnt it do it all the time.
Old 11-06-2012, 06:44 PM   #10
Nope.
The pump is pumping, but not sufficiently. So at high RPM high fuel usage the bike outruns the fuel supply and stalls.
Turn it off, cycle the key which cycles the pump, and it starts back up.
Old 11-06-2012, 06:50 PM   #11
ArodtheMan
Thanks for the advice. And what about if I can over 80 sometimes.
Old 11-06-2012, 06:52 PM   #12
Impossible to say.
My first step would be to follow the manuals recommendation for checking fuel pump. Then I would check float levels (but those dont usually suddenly change). It sounds fuel related IMO.
Old 11-06-2012, 06:59 PM   #13
ArodtheMan
Where do i find those manuals?
Old 11-06-2012, 07:04 PM   #14
http://lmgtfy.com/?q=SRAD+GSXR+service+manual
Old 11-06-2012, 07:06 PM   #15
tpayne3232
tpayne3232's Avatar
Motorcycle: 97 GSXR 600
I would check this if I were u
Sent from my SPH-M820-BST using Motorcycle.com Free App
tpayne3232 is offline   Reply With Quote
Old 11-06-2012, 07:10 PM   #16
ArodtheMan
How could I check that too?
Old 11-06-2012, 07:11 PM   #17
ArodtheMan
And how could that effect me at high speeds
Old 11-06-2012, 07:44 PM   #18
nemesis119
nemesis119's Avatar
Motorcycle: 2000 gsxr 600
I have the same bike. Mine did similar...and around the same speed. If the spring is weak, the vibrations/bumps make the plunger in the switch lose contact, shutting it down (not electronics, but the engine itself)
Put a ziptie around the sidestand switch (holding it in making full contact) and take it for a spin afterwards and see if it continues. If not..that was probly the issue. If it DOES continue, follow suit with what the others in here tell u to check
nemesis119 is offline   Reply With Quote
Old 11-06-2012, 09:23 PM   #19
ccmhunt
Carb Ninja
ccmhunt's Avatar
Motorcycle: 96 GSXR750, 07 CBR1000RR
Where did my post go?
ccmhunt is online now   Reply With Quote
Old 11-06-2012, 09:26 PM   #20
