new gsx r 600 srad owner : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-05-2012, 09:42 PM   #1
Pheonix89
Motorcycle: 1999 gsx r600 srad
so i just bought my bike and it wont start now so i have to pop start it and when im goin down the road none of my gauges work until i pull the clutch in and then everything works and my head light gets brighter what could be wrong with it?
Pheonix89 is offline   Reply With Quote Quick reply to this message
Old 11-05-2012, 10:37 PM   #2
williamhbonney
williamhbonney's Avatar
Motorcycle: 97 gsxr 750
Re: new gsx r 600 srad owner
Check the stator wires and r/r wires. They are usually fried. Your kickstand switch could be a problem, or your clutch switch.
williamhbonney is offline   Reply With Quote Quick reply to this message
Old 11-05-2012, 10:59 PM   #3
TwistedMister
TwistedMister's Avatar
yup might be wise to remove all the body work and go through every single connection and contact cleaning with electrical contact cleaner then filling the connections with electrical grease, check the harness for breaks and make sure all grounds are cleaned and solid.
repair any burnt connections, the usual suspects are the yellow headlamp loom connection (yellow 8 wire I think) and the connection that plugs into the R/R (regulator rectifier) there are how to's members have posted that walk you through the beef up process..
appears Suzuki may have used an inferior gauge in a few areas or something to that effect?
in any event don't half arse it, the electrical seems to be a trouble area for many SRADs so may as well go through it and inspect, repair and grease everything while your at it that way you know whats what as far as condition..
don't skimp on cleaning connections, use a bright LED flashlight or compatible to look down inside of each connector and make sure they are CLEAN and in good shape, use a good electrical contact cleaning solution, I like the aerosols for ease, use a good dose then inspect, repeat, repeat, repeat..
then when packing the grease inside the connectors use an ample amount and keep packing it in, blob some on then rub it in with your finger, repeat until you see the grease coming out the backside of the connector, this will help weatherproof it as well so use a waterproof grease.. also don't be afraid to use it on your bulb connections, tail bulbs signal, everything..
do all of this then test all of your electrical outputs with a muli-meter, you can test for leaks, amps and voltage...
there are way better electricians than I on this board so find their stickies or find someone that knows how to?
TwistedMister is offline   Reply With Quote Quick reply to this message
Old 11-06-2012, 02:07 AM   #4
Armi
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
Just a quick/stupid question on the grease....it doesn't matter if the grease is touching more than 1 connection at the same time, right?
Armi is offline   Reply With Quote Quick reply to this message
Old 11-06-2012, 06:38 AM   #5
ccmhunt
Superbike
ccmhunt's Avatar
Motorcycle: 96 GSXR750 (parts), ZX7/9RR F-USA AMA SBK, 96 ZX7RR STREET, 96 WSBK ECKL ZX7RR
No, pack it in
ccmhunt is online now   Reply With Quote Quick reply to this message
Old 11-06-2012, 08:02 AM   #6
Armi
Armi's Avatar
Originally Posted by ccmhunt View Post
No, pack it in
Old 11-06-2012, 12:38 PM   #7
MercMan007
"The Gloved One"
MercMan007's Avatar
Motorcycle: 97 SRAD 600
Waiting for SRADIATOR to post something funny... like a pic of personal lube..
MercMan007 is offline   Reply With Quote Quick reply to this message
Old 11-06-2012, 12:40 PM   #8
THE SRADIATOR
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
No, pack it in
I just love it when he talks dirty!
THE SRADIATOR is offline   Reply With Quote Quick reply to this message
Old 11-06-2012, 12:43 PM   #9
THE SRADIATOR
Your wish IS my command...: http://www.southparkstudios.com/clip...1/fudge-packer
Old 11-06-2012, 05:36 PM   #10
TwistedMister
No, pack it in
until it comes out the backside
Old 11-09-2012, 09:54 AM   #11
Pheonix89
thanks everyone iv now fixed the problem it was the wires
Old 11-09-2012, 10:37 AM   #12
Apok
ICBA
Motorcycle: '03 GSXR1000, '88 GSX 1100F, '92 GSX 1100F
Good to hear bossman.
Btw, a little late, but WELCOME TO GDC!!!!!!
The second happiest place on the internet.
Apok is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 11:17 AM   #13
Armi
Armi's Avatar
What's the first....your crack den?!?!?!
Old 11-09-2012, 11:23 AM   #14
Apok
ICBA
There's crack available online now?!?!?
Why was I not notified of this sophistication?
Old 11-09-2012, 11:25 AM   #15
Armi
Armi's Avatar
Uncle Fester needs to let you out more often.....lol
Old 11-09-2012, 11:32 AM   #16
dj_smurph
Motorcycle: 98 600 srad,97 aprilia chesterfield rs125
Pmsl
dj_smurph is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
