3rd time is not the charm.. : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 11-04-2012, 10:21 PM   #1
huesos
huesos's Avatar
here are pix of 3rd and final KN oil filter, just gonna buy OE from now on. all 3 had to be punctures to be removed, the spanner(bolt did not allow to get a grip), nor the pliers to remove oil filters worked. tried vise gripes near the end to try and get a hold of the bolt but just got crushed and could not get a hold of it. i even had to do, what ive done twice before and take off the fairings to get to the filter.
Sent from my uploadfromtaptalk1352089193050.jpguploadfromtaptalk1352089213633.jpggiXXer using Motorcycle.com Free App
huesos is offline   Reply With Quote
Old 11-05-2012, 07:14 AM   #2
COBRA90GT
Miss Sofonda Cox
COBRA90GT's Avatar
Re: 3rd time is not the charm..
Someone's been over-tightening your oil filters? No need to torque 'em down to ungodly amounts of ft/lbs...
COBRA90GT is offline   Reply With Quote
Old 11-05-2012, 07:27 AM   #3
AnthK7
AnthK7's Avatar
I had the same thing happen when I did my 1st oil change on my new bike the nut was rounded off before I started.
There is no need to make them as tight as hell. Just do up by hand tight then run bike worm it up then give it a 1/4 to 1/2 turn when it's wormed up.
Sent from my iPhone using Motorcycle.com App
AnthK7 is offline   Reply With Quote
Old 11-05-2012, 07:30 AM   #4
Puppalucci
Puppalucci's Avatar
Motorcycle: RIP Simoncelli #58 02-1000 pimp bike 05-750 track whore
Are you putting a thin film of oil onn the gasket before installing new filter?
I always hand tighten mine and hand loosen and never had one come loose.
Puppalucci is offline   Reply With Quote
Old 11-05-2012, 05:52 PM   #5
huesos
huesos's Avatar
well i didnt over tighten, i did put on a light coat of oil on gasket.. i usually dont even take off the fairings as my hands fit to remove the filter and can usually be done by hand or with the pliers to just loosen if it slips in my hand.. but live and learn. i know the first oil change i did on the bike, im pretty sure i over tighned just a tad. but the rest, 1/4 to a 1/3 of a turn after first contact of the gasket.
