fire from throttle bodies...:/// : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 11-04-2012, 07:01 PM   #1
rev.T.M.
Motorcycle: 04 gsx-r 600 with 05 750 swap, braided brake lines, hotbodies undertail, flush turn signals, sprocket kit, k & n airfilter, scorpion exhaust, angel eye hids/halo, double bubble, crg levers, pcIII,
Question fire from throttle bodies...:///
PROBLEM:
engine has been running rich and haven't had a good map, was getting a custom tune on Tuesday but now I think I have a bigger problem that I think I should address before tuning it. let me know if you think I should still tune.
My 05 750 wasn't turning on and when it did it was a really bad rhythmic low idle. I fixed that by agdjusting the fast idle to 2k rpm. after that when the engine started there was a thumping sound coming from the center of the block. seemed centered around the crank shaft, a neighbor said it sounded as if it wasn't running on all cylinders.
took the airbox off and checked the brand new spark plugs I put in. Cylinder 1 and 2 were clean while 3 and 4 were starting to accumulate carbon build up.
I tried starting the bike, I zeroed the pcv so no map was installed and I noticed smoke coming from the throttle bodies and at one point I saw an orange flame from cylinder 2. is this from excess fuel?
is my problem the fuel management? and what the fuck could the thumping be(not like rapid hammering like rods, but a deep rhythmic thump every beat on a four count). I have a video on my phone im going to try and post but its a shitty phone but you get an idea of what the thumping sounds like. it is not the gixxer ticking, rod chattering, and I checked to make sure engine is tightly fastened. I need help. haha
rev.T.M. is offline   Reply With Quote
Old 11-04-2012, 07:04 PM   #2
Re: fire from throttle bodies...:///
Impossible to tell with what you posted honestly.
My first instinct says cam jumped time. Hard to say though.
Moto_Joe is offline   Reply With Quote
Old 11-05-2012, 01:47 AM   #3
rev.T.M.
my bad there was a lot of info i just threw on here. hopefully this is a little clearer.
the problem(s):
1.enigine wont turn on (turns over but wont catch) and when it does theres a deep thumping
*recently installed pcV but no map yet. running as if it didnt have pcv installed.
2.cylinder 2 shot out a flame and smoke would come out of the throttle bodies when i was trying to turn it on. didnt see which cylinder but once i saw it, i quickly turned the power off.
3.pulled out spark plugs, cylinder 1 was clean as if it was just opened, nothing on it at all and the rest had carbon residue. does that mean cylinder one isnt firing? I think i need to run a compression test to see.
I checked the timing just incase it wasnt timed right, but at TDC the notches were in the right spot and there were14 points under the cam chain cover. So that knocks timing off the list right?
Old 11-05-2012, 02:18 AM   #4
rev.T.M.
also im not sure, but is the tension on the cam tension bolt suppose to be uniformly the same amount of force when turning it? because when i was turning it to tdc, a quater was real easy to turn and the rest required some force to spin back to tdc
Old 11-05-2012, 02:46 AM   #5
rev.T.M.
the thumping sound could be from pistons that are not perfectly tight in the cylinders. Im going to try to put fogging oil see if it stops. if not maybe there is excessive wear on my crankshaft which can cause a loud rythmic deep thump/knock
Old 11-05-2012, 06:07 AM   #6
Was it running before. What made you decide to start working on it. Back up a bit here.
Old 11-05-2012, 07:00 AM   #7
TheGeek
Stupid. Who's with me?
TheGeek's Avatar
Motorcycle: Anniversary Edition 600
I say take it to a professional. From this post alone, I really think you're in over your head already.
TheGeek is offline   Reply With Quote
Old 11-06-2012, 03:13 AM   #8
rev.T.M.
Do you know the answer to what it should feel like when turning the crankshaft adjuster bolt to TDC??
I have common sense and I am pretty good with my hands, this is my first bike that I bought as a project and have been fixing up from the ground up. I just need to know where the problem is and an idea of how to fix it and I can do it.
I decided to work on it because I bought it and it came with a bad engine, the pistons were bad, so I bought a used engine from a mr.motorcycle in texas. (the engine that I am asking about). it was suppose to be guaranteed to run and work.
I did the swap, plugged it all up correctly and all electrical worked, no FI codes. fixed the clutch, new plugs, new oil, checked compression (all good 150psi throughout all cyl). turns on the first time easily but doesn't idle well (don't remember if knocking was present, i was just happy it turned on). i wait a day and fix the idle.
another day goes by and when i go to turn it on it is hard to catch, but when the Engine does turn on after many trys it runs real rich: popping at the exhaust, dark smoke, carbon accumulated on the spark plugs and a weird knocking from the center of the engine.
for the last two days, it doesn't turn on at all. just cranks. pcv map is at a zero map. exhaust pops are louder. too much unused fuel.
started working on it because i have been fixing her up. it has compression, and spark. fuel seems to be the faulty factor. as for the knocking, i have no idea, hoping its not worn crankshaft bearings or a broken connector rod.
Old 11-06-2012, 05:57 AM   #9
If the plugs are in, what you are feeling is compression. If the plugs are out it is not completely smooth as each piston passes TDC there is a change in resistance.
Check compression again. It still sounds like it is out of time to me. Maybe even bent something.
Old 11-06-2012, 07:08 AM   #10
TheGeek
TheGeek's Avatar
Yes. Resistance variations based on piston position and relative angle of the crank shaft. Combine that with the load on the cams as they engage the valves.
Checked compression, but you're still worried about a broken rod? Dude... I'm not being a dick. Get some help before you make things worse.
Tell you what, have you checked your throttle body sync? Have you checked the cam timing? Have you checked the IAP vacuum lines?
Old 11-06-2012, 03:35 PM   #11
rev.T.M.
took it to my local shop, and compression is good, cam timing is good. everything I checked he double checked and said it was good; compression and spark. but when he cleaned the spark plugs and reinstalled , the bike would turn on but cylinder one wasn't working. after a min of idling it died and wouldn't turn on again, just forcing the starter. he didn't know what to do after this. I am going to the dealer tomorrow to check the throttle body sync and see if they can diagnose the problem.
Old 11-06-2012, 04:01 PM   #12
-JK750-
-JK750-'s Avatar
Motorcycle: 01 GSX-R 750
Did you try to disconnect the PCV completely?
-JK750- is offline   Reply With Quote
Old 11-11-2012, 08:16 PM   #13
rev.T.M.
So I got the problem fixed: it ended up being a bad vacuum sensor.
but now another problem arose, when you start the bike the bike revs it self to about 8k.
it wasn't as bad, before it would rev up to 5k and then down to 2k. I turned the idle screws and it idled down to 1k. rode it for a while but now it revs up to 8k on start up and the only way to stop it is to push the throttle closed. was about to cruise it into the garage because I didn't want to ride it anymore at least until this was fixed and then it died and doesn't turn on anymore.
Old 11-12-2012, 07:05 AM   #14
TheGeek
TheGeek's Avatar
Push the throttle closed???? There's your problem.
Old 11-12-2012, 11:47 AM   #15
Zippysport
I agree. You'll need to take care of that as a starting point. It should snap back cleanly, and all the way, even when the bars are at full left and full right lock.
Did you perhaps add an R6 throttle to the bike at some point? I fear some people may have done that mod without doing the other needed work to make sure the there was enough slack left in the throttle cable.
Zippysport is offline   Reply With Quote
