Clarification please!!! Generator/Stator/Coil/Magneto??? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-04-2012, 03:37 AM   #1
Bohn101
Motorcycle: GSX-R1000 K3
Okay, so I have a few questions, and maybe just one if it's the same thing.
Can someone please explain to me the differences for these charging system terms:
Generator
Generator Coil
Stator
Magneto
I think these may all be the same thing. But if my service manual says that the generator coil is bad, is that the same thing as the generator? Then think I found it referenced as a stator. So if I need a generator, does that mean I need a stator? You can see where I'm having some issues here.
Also, the regulator/rectifier a.k.a. the R/R, this is not an alternator, correct?
I'd appreciate some clarification on the topic, and I can't be the only one. Thanks for you input.
Bohn101 is offline   Reply With Quote
Old 11-04-2012, 04:34 AM   #2
Zlow28
16.8@186.1
Zlow28's Avatar
Motorcycle: 2006 GSXR 600
Re: Clarification please!!! Generator/Stator/Coil/Magneto???
the stator (copper coil/magnet thing), works similar to a car's generator. The rectifier, is the small squared looking thing thats bolted right behind the radiator. Different parts of the same charging system.
Zlow28 is offline   Reply With Quote
Old 11-04-2012, 09:48 AM   #3
Clanktank
Clanktank's Avatar
Motorcycle: GSXR750L0
The engine turns a magnet on the end of the crank, which is enclosed by a static coil (aka: stator/ magneto/generator) which is bolted onto the internal face of your stator cover. When the engine is running the magnet moves within the coil and induces into it an alternating (AC) current. The rectifier/regulator converts this to a DC voltage as the bike has a DC electrical system.
It's the reverse of an electric motor which turns electrical energy into mechanical motion, where this turns mechanical motion into electrical energy.
The rectifier gets very hot during this conversion as a lot of the energy it receives is wasted, in this case in the form of heat, which is why your rectifier is prone to failure and is one of the the first things to look at if you're having charging issues.
Maybe.
GSXR - There is no upgrade
GSXR750 L0
Clanktank is offline   Reply With Quote
Old 11-04-2012, 05:06 PM   #4
Bohn101
Thanks for the responses. That makes sense, I hadn't found it explicitly explained. All that made perfect sense.
Old 11-05-2012, 12:33 AM   #5
groundhogday
groundhogday's Avatar
Motorcycle: K1 SV650, L1 GSX-R 750
IF your rectifier happens to go bad, I'd highly recommend converting to a MOSFET unit from another bike. When the original on my SV quit working I replaced it with one from a late model ZX-6R. It barely gets warm even on hot days. There's a good writeup on how to do the conversion here. All of the big Japanese manufacturers are using MOSFET units for several models except for (AFAIK) Suzuki, so there are many suitable R/R's out there that you can find on ebay.
groundhogday is offline   Reply With Quote
