Where to mount Accel coils : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 10-27-2012, 09:09 AM   #1
mexgsxr1100
mexgsxr1100's Avatar
Motorcycle: 87 GSX-R1100
Any sugestions of where to locate a pair of accel coils on my 87 1100 Boiler?
I think there is not enoug clearance in the original location of the coils; I'm running pods, so maybe the best option is relocate the coils under the gas tank.
I will apreciate any ideas before unassemble the bike.
Thanks to everyone on this forum, this is my bible to mantain running my bike.
mexgsxr1100 is offline   Reply With Quote
Old 10-27-2012, 09:15 AM   #2
tonyc9928
tonyc9928's Avatar
Motorcycle: you know the kind. the ones with wheels. I don't care how many wheels. 1 will do.
Re: Where to mount Accel coils
I put my Dyna coils under the tank. Made an aluminum bracket that bolts to the frame under there in a couple bolt holes that are not used and I have plenty of room in there now.
I don't have any pics but it was simple and effective.
tonyc9928 is offline   Reply With Quote
Old 10-27-2012, 09:59 AM   #3
rodriguez
Motorcycle: 86 7/11 86 1100 87 1100 89 750 95 xr650l 86 ATC 125m
+1
My 86 1100 came with that plate.
I'll take pics tonight when i get home.
rodriguez is offline   Reply With Quote
Old 10-27-2012, 11:31 AM   #4
mexgsxr1100
Thanks. Tonight i will remove the tank, and search that holes, to make the aluminium brackets, and adjust all the cables. and connections.
Old 10-28-2012, 08:05 PM   #5
rodriguez
Sorry Mex.
Here are the pics.
Old 10-29-2012, 10:23 AM   #6
mexgsxr1100
Thanks man, i will use these mount position.
Did you use pop rivets to attach the new bracket to the frame?
I know there are small holes, but im scared to drill the frame. A lot fo people say, "Never drill holes in the frame". (i see you have another big hole in the frame, and do not see any crack or something).
Thanks again, i will do that job in the week. I got only the coils, and need to get a new wire set, and adapt it.
I will post pictures when the job was done.
Old 10-29-2012, 04:40 PM   #7
tonyc9928
tonyc9928's Avatar
I didn't do any drilling. I made the bracket longer and just flat so it overlaps the frame and used industrial strength Velcro to attach it to the frame. No need for the little spacers under the coils either.
Old 10-29-2012, 04:56 PM   #8
mexgsxr1100
Thanks Tony. Now i have an accel wire kit, so i will start the job these week (i hope tonight). Im searching an aluminium piece to make the bracket. I will do some tests and adjustements, to find the best solutions. Thanks to all for the suggestions and info.
Old 10-30-2012, 05:58 AM   #9
rodriguez
The PO made that, not me.
Old 11-03-2012, 11:06 AM   #10
mexgsxr1100
I found a pic of a great job in on other forum.
First i will mount it my coils provisionally (yo make tests and adjustements) , and when all is working ok, i want to copy that job.
Old 11-05-2012, 09:34 AM   #11
mexgsxr1100
Finally i have time to play with my boiler. Here are some pics of the ignition coil job (temporary, i wish).
Old 11-05-2012, 09:56 AM   #12
mexgsxr1100
Final pics.
I know it look like mexican style mount, but i want to respect the frame, and use the original thread holes. I dont have time to test the bike, but i crank it, with spark plugs out, and the spark was so much stronger than the standard coils. I start it, and sounds good, so i believe it was a good upgrade.
Old 11-05-2012, 12:02 PM   #13
tonyc9928
tonyc9928's Avatar
