Clanking sound, coolant in oil. : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 10-25-2012, 05:59 PM   #1
Atreto
My k7 600 has coolant in the oil tank and is making a clanking sound when i turn it on. Also when you rev it the sound speeds up. It is my first year owning the bike..Please help...........thanks
Atreto is offline   Reply With Quote
Old 10-25-2012, 06:43 PM   #2
pocar
pocar's Avatar
Motorcycle: K7 GSXR 750
Re: Clanking sound, coolant in oil.
maybe cracked or warped head or bad head gasket. i wouldnt start the bike anymore untill you find someone to check it out.
Has the bike overheated before, how long have you had it before problems started.
pocar is offline   Reply With Quote
Old 10-25-2012, 08:50 PM   #3
Zlow28
16.8@186.1
Zlow28's Avatar
Motorcycle: 2006 GSXR 600
Bad head gasket, and bad engine top end. Dont turn it on until it gets fixed. If you can do all the work yourself, youll save tons of money, if not, start saving.
Zlow28 is offline   Reply With Quote
Old 10-28-2012, 03:25 PM   #4
Atreto
I have a year with the bike.. No it has not over heated, the problem started two weeks ago.
Old 11-01-2012, 01:50 AM   #5
ty101
Motorcycle: gsxr750 k7 gsxr1000k8 triumph675 triumph955i
hi there bud sounds like a big problem, from what you wrote id take it in, see a noise like that means trouble, plus coolant mixing never a good sign, blown head gasket maybe, as for the sound could be a bearing gone....
easy way to check would be drain oil check for copper pieces/shavings, thats bearings if not could be a head problem best is to get it checked.
if you no your way around the bike you could pull the sump n check, and check the valve clearance for a bent valve i hope this helps good luck
ty101 is offline   Reply With Quote
Old 11-07-2012, 05:07 PM   #6
Rogerdodger007
Rogerdodger007's Avatar
Motorcycle: 2007 GSXR 600
Don't crank it up anymore . Fix it.
I learned to hard way when my car did this and kept cranking it to show people what it sounded like and made it worse. If your not mechanically inclined...dont try this repair yourself. If you like taking things apart and putting them back together..then maybe try it with a service manual. Bottom line.. cheaper to just buy another used motor from a wrecked gixxer and swap on the parts from the other bad motor.
Rogerdodger007 is offline   Reply With Quote
Old 11-07-2012, 06:58 PM   #7
Zlow28
16.8@186.1
Zlow28's Avatar
Any updates on this OP?
